T Bird Suspension Part wanted
http://forums.y-blocksforever.com/Topic9384.aspx
By paul2748 - 17 Years Ago
I know there are a couple of T Bird owners out there. I need the split collar that goes on the front bushing of the lower A Arm. Have one, need another for the other side. It is about 1 inch in height, 1 7/8 in outside diameter, 1/8 wall. Or maybe a piece of tubing with the same dimensions? A couple of pics are attached if I do this right. Thanks.
By bird55 - 17 Years Ago
paul, I know exactly what you describe, cause I just redid my bird. But I don't have any spares. Try the usual tbird supply house or Don Hyde in Dallas. good luck.
55Brodie (1/15/2008)
Paul:
I thought passenger an T-birds were similar, but I've never seen that spacer. How about using a section of tail pipe and make one?
My 54 has something similar, but not the same. Much smaller on the 54.
Your idea is a good one, but I've located one. Thanks for your help
bird55 (1/15/2008)
I got the name of Tony's Classics in Iowa - He has lots of used psrts - He had one, I got it. Thanks for your help.
