By '59Edsel - 12 Years Ago
I am in need of an extra road draft tube housing that screws into the valley cover. I am planning on modifying it to accept a pcv valve.
By 312T85Bird - 12 Years Ago
Late F-100 & F-250 trucks with 292's had that piece already set up as a PCV port, find one of those and you only need to install it.
312T85Bird
By oldcarmark - 12 Years Ago
You can do the same thing with a grommet and plastic type elbow like Ford used to use on the oil fill cap to aircleaner connection.Unless that original type has a baffle in it for oil control.The late style valley cover that you have has a baffle in it.
Great tips guys, and yes I do have a baffle on mine.
Are you putting the PCV at the back of the motor where the draft tube was or up front near the carb?
Yeah, I am planning on putting a pcv where the draft tube goes. I want to take a stock draft tube connector / housing like in my picture, and have it welded in a way that it'll accept a threaded pcv valve.
I think you may find that the threaded PCV wont work that way.The treaded end is the outlet end NOT the input side.It will be backwards if you thread it INTO the draft tube fitting.I think I am correct in the direction of flow with that type PCV valve.
Ah, I see. Thank you for that information. I will look into this more. I'll probably just do the grommet thing you mentioned before.
By unibody madness - 12 Years Ago
I have a spare down draft tube you can have shoot me a pm with your address.
The 223 6 has a pcv valve that threads on the motor side, and attaches to the intake below the carb, the way you describe. If you are set on your idea thats the way to go,same era as the 292.
Looking for just ONE more!
