keeping aluminum clean
http://forums.y-blocksforever.com/Topic92266.aspx
By lameyer - 13 Years Ago
Is there anything you can put on freshly bead blasted aluminum ( intake manifold for example) to keep gas stains and stuff like that from soaking in?
High Temp Clear Paint??
By MoonShadow - 13 Years Ago
Powder coat will help. I've used some that looked like unpolished aluminum. Chuck
By stuey - 13 Years Ago
i've never tried this stuff but it looks interesting.
http://www.roadsters.com/gibbs/
stuey
By lyonroad - 13 Years Ago
This looks tempting. I would like something for my brand new Mummert Script valve covers.
By bird55 - 13 Years Ago
At the speed shop today I was after something else, andt as I walked out I noticed the gibbs on the shelf. I remembered this post.
I started to pick it up to look at it an stopped when I saw the $20.00 price tag. Must be good stuff!
Looks like good stuff. I'll have to give it a try. Chuck
By NoShortcuts - 13 Years Ago
stuey (10/23/2013)
stuey
The web site information on this stuff is AMAZING! Definitely not inexpensive, but it sounds like THE material for preserving ANY metal that you desire to have a natural, waterproof finish on.
Lower viscosity than water, penetrates gaps as small as one micron... GooD GrieF!
Apparently available in a bottle at an earlier time. I wish it still was. -I've had too many aerosol cans go dead on me.
Sounds like it would be good for an aluminum intake and some cast iron pieces I can think of.
THANKS, Stuey! Smile
By 5d6fairlane - 13 Years Ago
I ordered some. I'll try anything once.
By Oldmics - 13 Years Ago
Been using Gibbs for years now.
$96.00 for a case of 12 cans delivered. Just picked up a case at Hershey.
Oldmics
By ian57tbird - 13 Years Ago
Wonder what the ingredients are. There are lanolin base products that supposed to do amazing things but I haven't tried them.
By Lord Gaga - 13 Years Ago
This stuff sounded GREAT until I read this;
" When used to protect metal from oxidization, Gibbs Brand will gradually become less effective. For best results, apply more Gibbs when your treated metal is no longer slightly wet to the touch."
It has to be constantly wet to the touch?
I say that's BOGUS! I think I'll save my money..........................
$20 per can at a local speed shop or $96 per case is a bargain compared to the prices listed on the www.roadsters.com site. After doing some research I found that a Canadian distributor for Gibbs Brand is not too far from me. I think I will check out their price, but I won't hold my breath.
P.S. Not as bad as I expected - $18.85 per can plus tax. I'll pick up a can tomorrow.
Engine clear coat. It yellows over time, but you probably won't notice it unless you have a fresh bead blasted part next to it. But I don't think there is anything that will absolutely prevent stains, except maybe never running the engine or driving the vehicle, and that is no fun.
charliemccraney (10/24/2013)
Engine clear coat.
Thanks Charlie, that's what I said in my first reply... Smooooth
The Master Cylinder (10/22/2013)
Gibbs Brand, ~$15.00 a can on Amazon.com. Free shipping.w00t
Someone let us know how it works. I don't like the part about "apply more Gibbs when your treated metal is no longer slightly wet to the touch" either.
And it does ALL THIS!!! w00tw00t
Gibbs© Replaces All Other Products Silicones, Penetrants, Degreasers, Belt Dressings, Contact Cleaners, "Other" Spray-on Lubricants, White Lithium Grease, Carburetor Cleaners, Ignition Wire Driers and more! Gibbs© can be used on any type of metal, wood, glass, leather,rubber and most plastics including: Aluminum, Brass, Bronze, Cast Iron, Copper, Steel, Magnesium, Titanium, Mild Steel, Stainless Steel, and Tool Steel &Chrome! Use Gibbs© toTonguerevent Electrical Connections from Oxidation, Lubricate Tools and Machinery Parts, Clean and Protect Saw Blades, Drill Bits, Protect and Clean Brake Parts & Bare Metal Surfaces on Vehicles, Machinery and Farm Equipment, Loosen Corroded Gears, Engines, Hinges, Latches, Bleeder screws and Bolts, Revitalize and Protect all Metals From Water, Remove Surface Rust from Chrome and Painted Surfaces Lubricate and Waterproof Latches, Locks, All Machinery & Equipment EXCELLENT for Waterproofing!Lubricate Computer HD Bearings!Clean,Protect Guitar Frets,Necks,Bodies,Bridges etc. Clean, Protect & Preserve precious Antiques. Starter fluid for all gas engines! Cleans, protects, preserves all Leather!
Lubricates AND cleans carburetors while preserving Leather...
Seen two pack paint used on engines, that is resistant to most solvents. Not sure on applying it as a clear coat only as it is usually primed.
