By mikhett - 12 Years Ago
Ive started the bodywork restoration on my 56 fairlane 2 dr ht.the engine and 3 spd tranny have been rebuilt but im looking to switch from the 2 bbl teapot carb and loadamatic dizzy,Who makes a aftermarket 4bbl aluminimun intake and an electronic dizzy that would work,i wanna ditch the point,condensor setup,thanks Mike
By glrbird - 12 Years Ago
http://www.ford-y-block.com everything you need and more!
By Ted - 12 Years Ago
Both Blue Thunder and John Mummert make aluminum single four barrel intakes for the Y. MSD makes an electronic distributor for the Y engines.
Here’s a link that gives specific details for the MSD distributor.
MSD Y-Block Distributor
By Rono - 12 Years Ago
Mike;
In addition to what other's have said, you can also get a 57 and later Y-Block distributor and install a Pertronix electronic ignition. I did that upgrade 6 years ago for my 56 Customline and haven't had any issues. If you want to spend a bit more dollars, you can get the MSD 8383 Pro Billet distributor. For my most recent engine build I went with that and I must say it was a very easy set-up. Even re-curving the distributor by changing the springs and bushings was pretty straight forward and MSD provides good instructions. Good Luck!
Rono
