T Bird parts
http://forums.y-blocksforever.com/Topic84191.aspx
Still have a few things from the bird motor I parted out. would like to offer here before fleabaying the things.
Tach drive distributor.
Steady rest & front mounts.
Exhaust manifolds.
By slumlord444 - 12 Years Ago
What do you want for the distributor? What year?
By PF Arcand - 12 Years Ago
Billy: I believe the actual T.Bird engines also had the rear vent style valley covers. Do you have a good one (no bent flanges etc) from that engine by chance?
By lyonroad - 12 Years Ago
Paul, there are 7 valley pans currently listed on e bay for $40.00 plus $13 shipping to point Roberts Wa. This one has the rear vent.
http://www.ebay.com/itm/FORD-ENGINE-MOTOR-Y-BLOCK-INTAKE-MANIFOLD-VALLEY-PAN/130945966856?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D261%26meid%3D9093400257638338680%26pid%3D100005%26prg%3D1088%26rk%3D4%26sd%3D130945964638%26
I stand corrected, there are 13. Two others have the rear vent but are over priced.
By speedster1 - 12 Years Ago
PF Arcand,
I think you may be refering to the valley pans which have the bolt on road draft tube ?
If so, I have two left which are good straight units.
Do you need a road draft tube also?
Regards,
John
motorcarinvestments@gmail.com
Another item I forgot to mention is I have the power steering bracket and the special bolt that goes in the water pump.
As far as valley pans there are many later model cars and trucks that used them, those are not baby bird specific.
Distributor is the earlier 55-56 model Loadomatic.
By Dave V - 12 Years Ago
I do have a freshly chromed valley pan with the rear vent hole for sale. $50. Dave V
By ecode ragtop - 12 Years Ago
Dave,I would be interested in the valley pan, Tom (815-871-8017)
