spring helpers
http://forums.y-blocksforever.com/Topic84174.aspx
By 55vickey - 12 Years Ago
Has anyone used leaf spring helpers on their mid 50s Fords. I need just a little help in the back at the current height that I'm running. If so, pic would be nice. Gary
By MoonShadow - 12 Years Ago
Are you having a problem with the drive shaft hitting on bumps or bottoming out? I used the add on coil springs that fit around the shocks. Didn't change the ride height but added some stiffness to the springs. I believe they are called load levelers. The ones I'm familiar are a kit with the springs and clamps to put on your existing shocks. They look something like these I found on EBAY. Chuck
http://www.ebay.com/itm/2-Gabriel-41165-Overload-Load-Leveler-Shocks-W-Helper-Springs-2WD-Ranger-/230891323224?pt=Motors_Car_Truck_Parts_Accessories&hash=item35c231ff58&vxp=mtr
By LordMrFord - 12 Years Ago
What about the gas filled shocks or adjustable air shocks?
Last week I put a set of KYB KB5517 shocks with shock extenders on, they're working ok I think, a lot better than it use to be. New springs with supposedly 1" drop in them, I'm thinking a lot more than that, just would like a little more security, big thing is, the driveshaft isn't bottoming out anymore!
