Posting pictures
http://forums.y-blocksforever.com/Topic8229.aspx
By 56 effie - 18 Years Ago
UnsureIs anyone having difficulty posting pictures? Every time I try the forum will not allow, comes up with a critical error, whatever that is. Regards Peter.
By Moz - 18 Years Ago
peter
do you have photorazor if not google it download it then run photo's you want to post through it thats what i had to do when i wanted to post photo's i got critical errors as well seems my photo's were to big
By f-100 bob - 18 Years Ago
Ditto:  Thats what I also had to use!  photorazer works great !!!   f-100 bob
By Ted - 18 Years Ago
Picture posting in the forums as it was prior to being moved to the current host site would appear to be history for the time being.  I’m told there is now a memory issue in storing pictures for forum purposes with the new location for the forum.  As such, the use of alternative means for posting pictures such as Photorazor and Photobucket are viable options.  The biggest issue with using outside hosting sites for pictures is if the picture at that alternate location is moved, deleted, or renamed, then that link is lost at the thread level and that picture is no longer viewable without the original poster fixing the link.  I see this happening frequently at other sites and is just something to be cognizant of.
By Jerome - 18 Years Ago
Moderators,
I've a jpg pic of my wheels which is only 143KB. That is not big. Yet, it will not upload due to a server error. Is it possible to find out and post the KB pic size limit in the pic upload area so us users can intelligently navigate this hurdle?
Jerome
By Jim - 18 Years Ago
Hi Jerome,
Please carefully read Ted's response above as to how you must display images.  Since I had to move  the hosting for the site and forum, uploading files directly into the forum is not possible.  Ted explains a work-a-round for this.
Just downloaded photorazor and resized all photos but I am still unable to post photosCrazy. I read the post by Ted but am still unable to understand what is going wrong.  Do I need to download the photos to some sort of web site where they can be accessed by all.  Regards a computer dummy.
I use Photobucket but would suspect that Photorazer is similar in that there is a link provided with your picture in Photorazer that has the [img ][ /img] brackets around it.  You copy that link into the buffer and then paste it into the thread.  The link in the thread then allows the photos to be viewed by directly accessing them from where you’ve stored them in Photorazer.  They are only viewable when the thread is being viewed or read and not during the editing mode.  If Photorazer works differently than this, someone can simply correct me on this.
Photorazor is just a resizing utility.  Photobucket or some similar online image hosting will still be required.
Use "Preview" to make sure the picture shows up before clicking "Post Reply"
Y Blockhead. I think I am going to buy a post office and mail out a photo to every member on the site. THAT would be easy!
Thanks TED will give it a go.
Ok, just downloaded photobucket so here goes
Ok that didnt work, attempt number2    http://i252.photobucket.com/albums/hh39/56effie/F100013.jpg
Ok that worked, thanks TED.
56 effie (12/15/2007)
Glad you figured that one out.  If the pictures are downsized to 600 or less wide, they can be inserted into the thread with the [im g][\ img] brackets around the link and not make the thread unnaturally too wide.  Being too wide causes text within all posts within the thread wider which then makes the reading difficult and the screen must be scrolled back and forth in which to read the text.
Widths being 300 wide is much easier for those that are on dial up and will also allow pictures to be placed side by side if inserting more than one picture.  If simply wanting the pictures to be top to bottom, then be sure to put a hard return behind each picture so that the next picture will know that it needs to be under the preceding picture and not to the right of it.  If putting pictures side by side, then put a hard return after each second picture to do the same thing.  Trust that doesn't sound overly complicated.
Pleased it worked for you, and that is one nice looking motor you have there Y blockhead.
 Merry Christmas to all. Regards 56 effie.
