Door panels
Home
Keeping The Dream Alive!
This n That
http://forums.y-blocksforever.com/Topic80792.aspx
Print Topic
Close Window
By MplsMike
12 Years Ago
Does anyone know of a vendor that makes door panels for a '56 wagon? I don't want them finished, only the panels themselves. My panels are either missing or too distorted to use as a pattern. Thanks,
By carl
12 Years Ago
You should be able to get the material from a upholstery shop to make your own if the old one is good enough for a pattern.
Carl
By MplsMike
12 Years Ago
Unfortunately my panels are either missing or in pretty bad shape.
By PF Arcand
12 Years Ago
Might be corrected, but I believe Lebaron Bonney in Philidelphia has premade panels for 56s. Used to be ABC Upholstery but was sold. Or you could try SMS Upholstery Fabrics in Canby Oregon. They may have the correct materials for your panels.
By carl
12 Years Ago
MplsMike (3/21/2013)
I have a panel that would work for a pattern that you can have for shipping cost,send me a pm if you can use it Carl
By The Master Cylinder
12 Years Ago
Dennis Carpenter lists them. The measurement listed is ~10" shorter than my Ranch Wagon. Maybe this listing is for a four door?
Door Panel
my door panels were warped also. After making a pattern off the door, I made new door panels out of ABS sheeting so it will not warp again. Comes in 24" x 48" Sheets.
Side note; Anyone else having problems with the "Insert Link" on Posting a Reply?
12 Years Ago
Oops, my bad. The number listed above is for the Effie. No wonder the measurement was so far off.
By 56_Fairlane
12 Years Ago
You can use Masonite for the door panels. It's easy to trim and works great. You can take a large sheet of cardboard and use it as a pattern on the door then transfer it to the Masonite. One pattern works for right and left doors.
