By 1955mainline - 12 Years Ago
got a new set of moog aerostar springs, but with the granada spindles it is to low for my taste. make me a offer, john
By lyonroad - 12 Years Ago
You can get spacers for Aerostar springs that go under the spring and raise them 1,2 or 3 inches. May seem goofy though, to put in a lower spring and then raise it. I have the Granada spindle with the stock springs and am curious how low the car is with Aeorstar springs. People rave about the ride they get with these springs.
its real low...i could not get the arms from my lift out from under it. i had to put wood blocks under the tires. then it only had about a inch of travel to the bump stops. these roads in the lovely state of ny would jar me out of the car. i would like to use them to keep the variable rate, who sells the spacers? thanks a lot, john
These are the ones I saw. Maybe they can give you some technical info. Looks like they are located in Minnesota. .mcbayperformance.com/2WD_PICKUP_FRONT_COIL_SPRING_SPACER_LIFT_KIT_p/1700t_series.htm I would be curious what you find out.
