Clutch disc,pressure plate and distributor for sale
http://forums.y-blocksforever.com/Topic80572.aspx
By lyonroad - 12 Years Ago
I have a re manufactured 10" clutch disc and pressure plate. Rebuilt and balanced by Champion Parts Rebuilders. Pressure Plate (original Fomoco) fits the car flywheel. Disc is for a 1"- 10 spline shaft. Says for '55 car in pencil on the box
Also a rebuilt (never installed) Autolite distributor with Pertronix Ignitor. C7AF 12127 AG D17 for a 1967 390.
Make me an offer. I can ship from Point Roberts Wa. 98281
Oops almost forgot - pp has light pitting indicated by arrows.
By Slick111 - 12 Years Ago
Hi I am down in Everett WA got a 60 F-100 with a 292 V 8 and 3 speed trans wondering if the clutch & P plate will fit with a mustang T-5 trans set up.
No Slick, the T-5 has a 1 1/16 inch diameter 10 spline input shaft. The clutch disk I have is for an original 1" diameter input shaft. I will be using a T5 so that is why this one is surplus. The pressure plate would work but I decided to get a complete new clutch set up.
On further reflection, I have a feeling that the trucks use an 11 inch clutch.
Ok Thanks for the info.
