By Trevwood - 12 Years Ago
I have a sump with the deepest part up front, need one with the deepest part at the back please.
In Australia thanks, Trev.
By carl - 12 Years Ago
do you need a truck oil pan or t bird? Carl
Would prefer a pretty shallow one so I can get the engine as low as I can without hitting the steering rod.
Not sure what vehicle came with what, do you have one Carl?
i have a couple truck pans but not any t bird pans,i will measure from the flat to the bottom of the pan and let you know what it is Carl
Cheers.
The truck oil pan i have is just shy of 6" from the flat to bottom of the pan measured on outside of pan Carl
By PF Arcand - 12 Years Ago
This subject has come up before, & it seems that the alternative pans from trucks & T-birds aren't really rear sump pans. So they sometimes don't solve the clearance problems. Has anyone ever considered say, 1" down from the pan mounting area, using a cutting blade & removing the entire pan bottom & turning it 180 degrees, and re welding it on? It would of course require closing the side hole in the pan & drilling a new hole on the drivers side, closer to the oil pump & shortening the oil supply tube. A somwhat involved project, but it could work, I think. Yes, no?..
carl (1/8/2013) The truck oil pan i have is just shy of 6" from the flat to bottom of the pan measured on outside of pan Carl
That measurement would be the deepest part wouldn't it Carl?
If so how deep is the shallow part at the front please? Trev.
PF Arcand (1/8/2013) This subject has come up before, & it seems that the alternative pans from trucks & T-birds aren't really rear sump pans. So they sometimes don't solve the clearance problems. Has anyone ever considered say, 1" down from the pan mounting area, using a cutting blade & removing the entire pan bottom & turning it 180 degrees, and re welding it on? It would of course require closing the side hole in the pan & drilling a new hole on the drivers side, closer to the oil pump & shortening the oil supply tube. A somwhat involved project, but it could work, I think. Yes, no?..
This has entered my mind too.
Paul: I did that very thing about 42 years ago when I put a 292 in my '33 Ford pickup. I have a flathead in the truck now, but that 292 with 312 pistons and that pan is still sitting in my barn.
Trevwood (1/9/2013)
carl (1/8/2013) The truck oil pan i have is just shy of 6" from the flat to bottom of the pan measured on outside of pan CarlThat measurement would be the deepest part wouldn't it Carl? If so how deep is the shallow part at the front please? Trev. I will get that measurment for you.Someone had a picture of the truck and t bird pans posted on this site but i did a search and couldnt find it Carl
By Ted - 12 Years Ago
Here are some links to oil pan sump discussions. http://www.y-blocksforever.com/forums/Topic74338-3-1.aspx http://www.y-blocksforever.com/forums/Topic53516-3-1.aspx#bm53893
By lyonroad - 12 Years Ago
My 292 came to me with a rear sump pan and after I removed it I found that it was originally a front sump pan. Someone before me had cut the oil pan mounting flange off, turned it around and weld/brazed/epoxied it back on. One corner had been massaged (as they say in the hot rod magazines) with a ball peen hammer to clear the oil pump, small sheet metal pieces were welded into the corners and the oil pick up tube looked like a pretzel. It isn't pretty but it didn't appear to leak. I think with care and planning someone could do a better job. Its no longer straight as it was extremely difficult to remove.
Here are some pictures. (I hope this works)
Trevwood (1/9/2013)
carl (1/8/2013) The truck oil pan i have is just shy of 6" from the flat to bottom of the pan measured on outside of pan CarlThat measurement would be the deepest part wouldn't it Carl? If so how deep is the shallow part at the front please? Trev. I measured the shallow end and it is 31/2",also the picture Ted posted shows the pan i have is a pickup oil pan Carl
Call me please Carl 0409506079, Trev.
Trev
Just sent you a pm Carl
Thanks Carl.
Still looking for one in Aus please.
Got one.
