Stock ECZ-B intake manifold testing (again).
http://forums.y-blocksforever.com/Topic78123.aspx
By Ted - 13 Years Ago
As a continuation of the ECZ-A manifold results that were posted within the last couple of weeks, here are the dyno results after running the Lincoln Teapot and a couple of other carbs on a dead stock, never modified, unmolested, as delivered from Ford, ECZ-B iron intake manifold.  The step at the bores under the carbs is still present on this intake.  The Lincoln carb was used with an upside down tapered carb adapter.  The other two carbs had the 1957 7/16” Bakelite spacer under them but the spacer has been reworked to allow the larger carb throttle blades to work freely.
Horsepower – Stock ECZ-B Intake with various carbs
Rpm
Lincoln Teapot
625 Demon Street Fighter
750HP Holley vac sec
2500
146
128
143
3000
190
185
185
3500
221
221
213
4000
241
249
240
4500
249
268
260
5000
253
277
271
5500
246
276
273
Peak@rpm
255@5100
279@5200
276@5200
Torque lbs/ft – Stock ECZ-B Intake with various carbs
Rpm
Lincoln Teapot
2500
306
269
300
3000
333
324
324
3500
331
332
319
4000
316
327
315
4500
291
313
304
5000
265
291
285
5500
246
263
261
Peak@rpm
335@3200
333@3700
324@3000
Because the 600 vac sec carb that was used with the ‘A’ manifold is no longer here, I substituted one of the new Demon carbs and made a single pull with it.  That carb has much smaller primaries and makes up for it with a ‘Goggle’ valve in the secondaries making the carb close to being a three barrel.  Jetting was in the ballpark but could have still stood some tweaking if I was going to leave it on the single four manifold.  That tweaking will happen when two are them are used in the dual quad intake test.
Unlike where the various carbs were run on the 1956 ECZ-A intake and there was not much difference in power outputs due to the flow limitations of that particular manifold, the 1957 ECZ-B manifold even in its stock form does respond nicely to the larger cfm carburetors.
Here’s the link to the ECZ-A intake dyno test results.  http://forums.y-blocksforever.com/Topic77765.aspx
And here’s a picture of the Demon Street Fighter carb sitting atop the stock ECZ-B intake.
By DryLakesRacer - 13 Years Ago
The numbers up to 4000 do not suprise me at all. Small bores were known for this but always ran out at the upper end. It will be neet to see these numbers on you dual quad tests too. I'll bet the 4GC's will make a good showing as well as the little Holleys...............Thanks
