By Ol'ford nut - 13 Years Ago
Need the pieces that mount on engine for auto trans kick down. We have the long rod that goes down to trans and the linkage that mounts on firewall down to footfeed, but everything else is missing. Car is a 55 with V-8 and automatic trans. Any help is appreciated, even some good photos and we might try making it.
By junkyardjeff - 13 Years Ago
2 bbl or 4 bbl?
By Ted - 13 Years Ago
Here’s a picture of the kickdown for a 55 Ford with the 4V option and FordOMatic.
By slumlord444 - 13 Years Ago
The '55 4 barrel is rare unless it is a T-Bird.
By carl - 13 Years Ago
The 55 4 barrel carb. is fairly easy to find but the linkage is the rare one Carl
By Oldmics - 13 Years Ago
P.M. sent. Oldmics
Just what is the difference between the 2 and 4 bbl trans linkage parts,all I know is when the 55 gets a Y block again it will have a newer trans so I can use a 6 cylinder throttle linkage for simplicity and aftermarket kick down cable.
By Ol'ford nut - 12 Years Ago
OLDMICS Send e-mail and was returned. Send picture to fultonjc@msn.com Thanks
I keep checking my e-mail--- no reply.
By 312T85Bird - 12 Years Ago
Call Mike at Zeb's Auto Salvage in Tigerton, Wisconsin. He had that linkage for a two barrell the last time that I was there. He ships. 715-754-5885. Tisler Salvage in Cato/Reedsburg, Wisconsin has a '54 Mercury with a four barrell that should have the linkage that you need. I do not know if Tisler's ships or not. Call Jeff at (920) 732-3669
Tom
