wanted:dual row driven pulley for VR57 or 58 Paxton
http://forums.y-blocksforever.com/Topic76084.aspx
By JPotter57 - 13 Years Ago
I realize its a long shot, but. Does anyone have a 2-sheave pulley they would want to sell? Or, if not, dimensions so I could have one made or modify an existing pulley? I found the multi-row crankshaft damper, just need the upper and idler now, will worry about the idler after I get a driven pulley for the Paxton. Let me know what you have. Thanks.
By pegleg - 13 Years Ago
Jim, Give a month and I'll have some more castings for this.
By suede57ford - 13 Years Ago
I have another friend who will buy a couple as well.  Let me know when they are done.
Thanks Frank for all your efforts in reproducing this stuff to help us out.
By MoonShadow - 13 Years Ago
Frank,
Did you do the pulley for the supercharger too? Chuck
Thanks a ton, Frank. I know everyone appreciates the effort you hasve put into making this stuff available to us...Let me know when they're done..
By Y block Billy - 13 Years Ago
Could 2 shieve generator or alternator pulleys be made to work for that?
I kind of doubt it, the way the pulley is made to bolt onto the input shaft of the blower. It is a blind hole, and is set at a certain depth. I do have a line on a couple right now, just trying to work the deal. I will know about the better of the two tomorrow sometime, then if that's not doable, then I have a deal working on another one, just have to see. I'll post up what I find.
