By grandpas4dr56 - 13 Years Ago
Looking to sell my not needed parts, i have front spindles, front springs, manual steering parts everything except for the gear box, fordomatic trans rebuilt 10000 miles ago, rear end everything except brake lines, 2 y block intakes one is the small 4 barrel the other is the big 2 barrel, 3 motorcraft 2100 carbs that need rebuilt, guage cluster complete minus wiring, various y block waterpump pulleys and brackets, 2 harmonic balancers, set of stamped steel valve covers powder coated wrinkle finish black, misc. small parts for y block. Set of stock steel wheels, master cylinder for manual brakes, non power steering horn ring, and some other small parts. Pm me and make me an offer is there is anything you need or want. I can get pics for you if requested.
Interested in your wheels, where are you located?
Near fauetteville nc
By 56 VIC - 12 Years Ago
Hi I am in need of a support/brace from your car. I need the brace that connects the firewall to the floor board. I need the passenger side. The brace I needs to be taken off the car with a bit of care,,usually it is chisled off or the spot welds can be drilled out. Thank you, please let me know if you can help me. Tom - 619-804-1460
By ronsplace - 12 Years Ago
Hi: Saw your post and would like to know if you have an original door lock off the passenger door? I don't need a key, just the lock. Thanks, Ron.
By Bjmayberry2 - 12 Years Ago
What are the numbers on your Intake XXX 6049-X??? Should be cast in the top of the rear runners. What are you looking to get for it? Do you have the mounting studs, bolts etc?
By orgunvs - 12 Years Ago
I need a '56 temp sender, gas gauge and sending unit, and the ign switch lock cylinder and key.
Do you have any of this stuff?
Thanks, D.P. down in Florida
By carl - 12 Years Ago
orgunvs (10/9/2013) I need a '56 temp sender, gas gauge and sending unit, and the ign switch lock cylinder and key.
Thanks, D.P. down in Florida I have all the parts you need,sent you a PM Carl
