Blow Thru Carbs
http://forums.y-blocksforever.com/Topic72904.aspx
By Rono - 14 Years Ago
Anyone have any experience dealing with Pro Systems Racing Carbs? You fill out a spec sheet with all the variables on your engine, trans car weight ect and they build the carb to your needs. Their cost to custom set-up one of their carbs seems to be less than buying a Holley HP double pumper than having to modify it for blow through application.
Rono
By 57 ranchwagon - 14 Years Ago
I have done some studies on there single venturi carb and it looks pretty good. I know of a few who have run pro system carbs and were pleased with there performance. These were all N/A applications so no advise on the blow thru but the fit and finish look good and the two I know of are enough for me to try one on my next engine.
Thanks for the info. I'm still talking to them and tonight they told me of their new 730 cfm gas blow through carb built to the specs I provided would be $890.00 plus $16.00 shipping. Not outrageous, but not chump change either. They also told me that based on all the specs I gave them on this stroked and blown motor, that their computer program indicated I could expect 550 HP out of this motorw00t I'll believe that when I'm standing ouside the dyno booth and reading the printout.
Rono.
