By brokengate - 14 Years Ago
http://www.ebay.com/itm/1956-Ford-Victoria-Y-Block-Motor-/120890679004?pt=Motors_Manuals_Literature&fits=Year%3A1956%7CMake%3AFord&vxp=mtr&hash=item1c25a55edc Not mine, and please to note Motor runs excellent but zero oil pressurehow can that be?
By lowrider - 14 Years Ago
That could be a good deal or a money pit for someone.
Wow, "Reason for selling: Going for Ford 302."
That's like saying "I don't like torque." Boy is he going to be disappointed.
Wish it was a little closer.
By Moz - 14 Years Ago
$1500 is a bit steep if its got zero oil pressure & how can it run well. i had a guy tell me the other day i should replace my 272 with a 289 stroked to 302 because it would be more powerfull. the idiot couldnt understand why i was laughing at him
By slumlord444 - 14 Years Ago
Hope he has not run it long with no oil pressure. Guess is oil pump or oil pump drive failed. Lot of expensive parts there. Could be a bargain, or not.
By 54yblock - 14 Years Ago
I scored on this one as it was in my home town. Hopfully it won't be anything serious. I'm thinking pump drive also, weak point on y block. Was told it only ran 2 miles down the road, and as he turned back in to his place lost pressure. He had a lot of machine work and expensive parts, probe forged pistons, probe rods, clay smith cam and matching lifters, 312 crank in 292 block, whole rotating assy. blanenced, dove roller rockers, custom stainless headers 2 into one, nice quality work. Not to mention all the head work on the 113 heads. And to top it all off a blue thunder intake. I can't wait to get it home and go through it. It's still in his 56 victoria, and he has to pull it. As mentioned in earlier post if nothig else it was worth the parts.
By MoonShadow - 14 Years Ago
Did he have an electric or mechanical pressure gauge on it? If not I think I'd try a pressure reading from the port on the block directly. He never mentioned if he was getting any oil to the upper end. With only 2 miles you may have bought a real score. Chuck
Told me he had 80 psi. oil pres. when he first started it. This seems high to me. That's why I suspect oil pump drive twisted then sheared. I'v seen this before. The engine was bluprinted so there is no give anywhere and oil as we all know does'nt compress. Something has to give, thus the week link, pump drive. He told me that he was frustrated after all that time and money and just wanted to move on. Even if I have to go completely through it I believe I got a good deal on it. All the machine work was done right as best I can tell. Things like leaving the oil slinger on the crank when it was machined for the 292 block. Also had oil groves done to lifter valley. Water passages drilled between center cyls. to match heads. I will check it with direct reading gauge when I get home.
54y I'd be very interested in where the headers came from, or who made them, got any info?
I think you got a good deal no matter what, and possibly a great deal. I am thinking the simple thing is to pull the distributor and see if the shaft is there and in one piece. If it is there I use a junk old distributor with the distributor gear removed and a nut welded to the top of the shaft to turn it for priming a new engin. Will also work to see if oil pump is working.
By Ted - 14 Years Ago
54yblock (4/5/2012)
I scored on this one as it was in my home town. Hopfully it won't be anything serious. I'm thinking pump drive also, weak point on y block. Was told it only ran 2 miles down the road, and as he turned back in to his place lost pressure. He had a lot of machine work and expensive parts, probe forged pistons, probe rods, clay smith cam and matching lifters, 312 crank in 292 block, whole rotating assy. balanced, dove roller rockers, custom stainless headers 2 into one, nice quality work. Not to mention all the head work on the 113 heads. And to top it all off a blue thunder intake. I can't wait to get it home and go through it. It's still in his 56 victoria, and he has to pull it. As mentioned in earlier post if nothig else it was worth the parts. Congratulations on your acquisition. The rubber O-ring behind the flange nut at the oil pump is always a good place to start looking when the oil pressure unexpectantly drops off on the Y engines.
Well the verdict is in. Turns out it was nothing serious. When I got it home I pulled valve cover then disty. I put my dummy disty shaft in and turned it with my drill. Could tell pump was ok and heard gurgle at rocker arm bleed tubes. Then all of a sudden oil running out from oil filter adapter. That's all it was, bad rubber gasket. Took it apart, cleaned and dried it good and put new rubber ring in DRY and good to go. I assume it failed in the two mile test drive he made. Probably ran short on oil about that time and out of frustration dicided to move on with the 302 crate motor. This was a lucky break for me. I had been collecting stuff to do a motor for a 54 crestline two door i'm working on. Now I've got the motor and can concentrate on the body. Had open heart surgury last Sept. and just now getting back in the grove. Getting this engine puts me back on schedule. I am going to finnish my test stand now and run it before putting in car, can't wait !!
Awesome, glad it was nothing major. Seems strange that the guy didn't even notice any dripage when he parked it...
Congrats. I had a feeling it was nothing serious. You think the guy would have noticed the crankcase was empty and there was a mess under the car.
Well I finally got this engine mounted on the stand to run it. When it first fired the oil pressure went to 60 psi. then after about 4 or 5 seconds down to 10 psi. and fluctuated. Went strait to oil pick up tube nut on pump as Ted suggested and wow it was only finger tight. Gave it a few turns and wala. Engine has a great sound, can't wait to finnish car body work and mount in and go woops just noticed missprint in description the block is an ecz not x. http://youtu.be/yHHjfBLxf0g
