Reasonable source for 312 main and rod bearings
http://forums.y-blocksforever.com/Topic69273.aspx
By slumlord444 - 14 Years Ago
Replacing main and rod bearings as a precaution while my engine is apart. Crank and bearings look fine but never a bad idea to go with new ones just in case. Local parts store ordered a set of .020 under mains and .030 under rods. Came up with $180 for mains and $96 for the rods which he thought was way too high. I checked Summit and they were very close. Anyone have a cheaper source? I am thinking this is the going rate. If so, no problem. I will stay with the local guy as long as he is in the ballpark.
By PF Arcand - 14 Years Ago
Apparently 312 Main bearings are in short supply. Did you check J. Mummert's link? Also Schumann's Sales & Service, 227 W. Mayne St. Box 128, Blue Grass IA 52726. 563-381-2416 fax 563-381-2409. Also Egge Machine, Address ? they advertise in Hemmings etc.
Further to prevous post.- Found a Schumann's Ad from 2008. Cleavite 77 Con rod bearings were $48.00. However Cleavite 77 mains were $168..
By 314 - 14 Years Ago
some good deals on mains on ebay of and on.
just checked ebay mains 108.someone has a set of .030 for 35.but thats no good to you.last week their was a .020 set for 40.just check every now and then.
Mummert lists rebuild kits but not the bearings seperate. Will check Ebay. Sometimes we have to pay to play.
I found a set of mains and rods on Ebay from Falcon Global for $163 shipped. Anybody know anything agout them? Sent them question to find out who manufacturer was.
Decided to bite the bullet and go with the local parts guy and a known quality of materials. Got the body back from the painter today.
By DualQuad312 - 14 Years Ago
Hi there...Do a google on Falconglobal.....there major supllier of engine parts....I paid $120.00 for main bearings.....they probably would give you a better deal then your price for the rods too..
Jeff
By John Mummert - 14 Years Ago
As far as I know the Falcon Global bearings come from Taiwan. That may or may not be a bad thing. I haven't bought any yet.
Be advised that Clevite has discontinued 312 mains and Federal Mogul might be doing the same so we might all be trying the import bearings soon.
I saw Summit trying to sell Y-B rod bearings for $23 a PAIR!!! on ebay. So that's $184 a set?
That set of -.030" 312 mains on ebay is missing the thrust main.
As I stated earlier, I went with my local parts store and the $180 mains and $96 rod bearings and name brands. I think the mains were Federal Mogel and the rods were Clevite but I not able to check my records on the brand names at this time. Summit's prices were about the same as the local guy. There may be cheaper engines to build, but I still love my Y-Block!! Machine shop is done with the block so I should be able to start with short block assembley soon. Need to install dash pad in car so windshield can go back in also. May do that first because I find it better to do the jobs that I hate first.
Chrysler mains can be made to work in a 312.  The thrust main takes a bit of "engineering", but the other four can be used as is if new tang notches are ground into the block and caps.  If you can salvage your original thrust bearing the rest is a relative easy modification.  I covered all this several issues ago in Y-Block magazine.
I have aset of 312 bearings I bought about a yr or less ago...can't recall off hand.....they are clevite bearings...and I'll check the basement tonight when I go home....
Best Regards,
Jeff
hi The bearing I recieved from Falcon Global are Clevite bearings...there stamped on the backside of the bearings.....I think I bought them about a year ago...
Best Regards,
JeffSmile
