T-Bird Engine Front Frame Mount
http://forums.y-blocksforever.com/Topic66315.aspx
By suede57ford - 15 Years Ago
I need the front motor mount bracket that welds to the frame crossmember on a 55-57 Thunderbird.   It is the steel channel looking part that the front motor mount sets on, is about 5" wide, and has a large hole for the motor mount to bolt to.
If anyone had done a mustangII, fatman clip, a later model engine swap, or has a parts frame they probably cut an original one off the frame crossmember already.  Mine was removed during a past engine swap and I"m putting a Y-Block back in it and using original mounts.
I can email a picture for verification of the part I need if necessary.
Thanks,
Pat
pmfleischman1@mmm.com
By Duck - 15 Years Ago
Incoming PM...
