By Apache - 15 Years Ago
Looking for a good steering wheel ring for my 57' fairlane 500. Need it to be in driver/cruise-in condition.
Thanks guys.
top
By DualQuad312 - 15 Years Ago
I believe your talking about the horn ring correct? Power or non power steering? Power steering had the words Master Guide power steering in gold letters. Non power steering was plain with no writing... Jeff
By Duck - 15 Years Ago
I've got one off a Thunderbird, if you'd be interested. It should make "driver quality" when given a once-over. I'd let it go cheaply, if you wanted it. /Duck
By Mark T - 15 Years Ago
I think I have a one for a power steering car. Let me know if you have any interest.
By PF Arcand - 15 Years Ago
Appache: If not to fussy, I believe a 58 or 59 will fit and looks similar.
I got a 59' but the button and everything doesn't fit and match up :-(.. anyone have a 59' button, etc?
to the top...
By speedpro56 - 15 Years Ago
William, look up item # 380395828090 under 57 fords, this may be what you're looking for.
Apache: Not sure of your situation, but you say the 59 horn ring unit won't fit? It should look very similar but the pieces on the back are different due to the horn setup being different from 58 on. If you have the original 57 pce, (?) you can switch the back pieces & it should fit.. If I understand your situation ?.
It's not just the back piece, the little plastic button/emblem is a tad to small and has a tiny tab at the top that doesn't allow it to fit properly.
speedpro56 (12/27/2011) William, look up item # 380395828090 under 57 fords, this may be what you're looking for.
That's the one for a 57 yes. Would be nice to have but a.) already spent $75 on the 59' ring and b.) I can't shell out another $150.
By Apache - 14 Years Ago
bump..again
By PF Arcand - 14 Years Ago
Apache: You've lost me.. ? You are trying to swap the 57 emblem piece to the 59 ring? The 58 or 59 ring I had was fairly close to the 57 in look and fit except for the back horn pieces which should swap. Why not just use it as is, at least until you find one at a swap or whatever? Only a phillistine would question it.. or am I totally missing something here?
By pasngas - 14 Years Ago
been watching this post and have taken pictures of my two horn rings -- first two pictures the emblem is silver outside crest (camera flash looks gold but its silver|) the last two pictures the emblem is gold outside crest--both of these are very good shape -- not perfect but rating 9-9.5 outta 10 -- silver crest price $120 shipped gold crest price $130 shipped thanks for now Laroy
yes, they look similar.. yes, the back horn piece will swap. NO, the plastic buttons center caps DO NOT swap. I'm just seeing if anyone had one lying around, before I go and make my own custom one. Being the don't have a repop readily available cap for the 59', find NOS is my only hope :-/
