junkyard jeff
http://forums.y-blocksforever.com/Topic64380.aspx
Jeff, I saw your ad on another site, looking for some C or G heads.  I have a pair of milled (.060 with the intake side also milled) Cs, the ones Ted tested in his cylinder head comparison dyno test.  They made just a few less horses than stock Gs.  You can look it up on Ted's report of the test.  They are the milled Cs with no porting.  Anyway, they can be yours for $150, I live about 45 minutes from Dayton.  They are ready to run, but probably need stronger springs for high rpm use, the ones on them are stock.
By junkyardjeff - 14 Years Ago
Are milled heads going to be a problem in getting the intake to seal and I am not wanting to go with excessive compression since its not going to be a race motor.
By Ted - 14 Years Ago
Here’s the link to the cylinder head test.  John’s heads are the ones making 288HP & 336 ft/lbs Torque.
http://www.y-blocksforever.com/forums/Topic61587-3-1.aspx
Because the intake side of the heads were also milled, intake manifold fit is not a problem.
I am interested in them.
Jeff:
Email me direct, feistritzer1[at]msn[dot]com or call 765-282-1067.  I may hve said I'm 45 minutes from Dayton, actually it's 45 min. to the airport.
I will give you a call this week,it will probably be a couple weeks or slightly longer before I can pick them up.
Jeff:
No problem, you say you are interested, so they are not for sale to anyone else until you make your decision.
