Holley 2110 stainless fuel line carb inlet connection...Pics
http://forums.y-blocksforever.com/Topic62590.aspx
I got some stainless lines from Vintage Speed for the 3 94's. Birthday present. The fuel lines have compression fittings at the carb inlet ends. Will these thread directly into the carb inlet on the carb body and seal? Or do I need an adapter? The threads are correct and not NPT fittings.
By pintoplumber - 14 Years Ago
Mark, I'm using those fittings with brake line tubing. Not ss of course but it seals well.
Mark, be carful when tightening those fittings. I they are like the ones I got from Vintage Speed for my 97's they are not S/S but chrome plated brass. Also don't polish them to aggressively or you will polish thru the thin chrome.
Sorry I can't answer your question about the fittings sealing, the Strombergs have flared fitting.
Charlie advertises this set as polished stainless steel. The stuff is thick-walled, so flaring doesn't look possible due to cracking. Here is the description:
FUEL LINE-3X2-DELUXE KIT polished stainless-with fuel block Our 3x2 Polished stainless fuel line kit with block. This is made with the best materials--
All plated and polished fittings- 3/8" polished aircraft .035 wall stainless tube bent in special fixtures. Fuel block is free standing show chrome plated with all fittings 1/4"npt. This kit does not include the fittings that go into your carbs. Comes with 15" length of tube for connection to stock fuel pump or firewall electric pump. Custom built for your application. When ordering specify your carb type and the manifold your using in special instructions box on order form. I have all the more popular carb and intake combinations already made and ready to ship. The fuel block can be reversed so your line comes in from the front.
By aussiebill - 14 Years Ago
MarkMontereyBay (8/23/2011)
Mark, perhaps you should be asking charlie if you have any doubts, i wouldnt think he,d sell or advertise them if they werent right?
By lowrider - 14 Years Ago
I'm using that same set-up on my 57 for 3yrs. now. Had the carbs off a number of times without any problems. Had to tweak the line to the rear carb when I installed a spacer w/a vacumn fitting last year but everything is still fine.
