Ford o matic
http://forums.y-blocksforever.com/Topic62267.aspx
By 56 Mercury - 15 Years Ago
I have a Ford o matic transmission that I would like to find out what year it was manufcatured for, what engine was it intended to be mated with, and the case size.  (Did not find on Charlietranny listing)
Nameplate: PAW-7003-D, s.n. 68-117646, trans case PAW-7006-A, bell housing PAR-7975-A.
Trans case appears to be a "medium" as the length is 10 7/32".
By Teros292 - 15 Years Ago
This was on Mercury parts book:
Year_ 1956
Carburetors Part Number: Carter ECZ-9510--F
Engines C.I.D.: 312-4V
Automatic Transmissions Model No.: PAW-7000-D Steel Converter
Type: S/R Single Range Transmissions Only
Serial Number Prefix: 68
I have good luck with the Ford Transmission Forum. The moderators there are good with the old stuff as well as late models. They should be able to give all the info you need.
The Ford Transmission Forum
http://www.network54.com/Forum/260730/
