I'm heading up Thursday morning, I75 to I71 to I70, hopefully leaving the driveway by 9:00am. That should put me in Chattanooga around 11:30. Anyone else on the same time-frame?
If you will be ahead of me, drop off small boxes of Y-Block parts every 100 miles or so. That way I should make it
By yehaabill - 14 Years Ago
Y-Guy Charlie: TRUCK? .....Just thought I'd ask before Dennis beats me to it!!l Hope to see ya there.. Bill
By 46yblock - 14 Years Ago
Have a memorable trip .
By pintoplumber - 14 Years Ago
Are you leaving this coming thursday? That should give you plenty enough time.
By Moz - 14 Years Ago
good luck charlie hope this is the year the truck decides it wants to go
By bird55 - 14 Years Ago
Hey Charlie, I'm not going this year but I wish you the best trip. I've driven my bird up to Columbus before and it's a similar distance from my place to what you are about to do.
A lot of guys on here wouldn't even think about it without a trailer or a chase vehicle!
This is your year. You can do it.
By speedpro56 - 14 Years Ago
Wish you were coming Alan because I won't be bringing my bird and we sure could use some street birds competing. Instead I'll be bringing my 56 Sunliner in it's place. I'm still putting my money on the street birds and and hoping there numbers will pick up. My new crank simply didn't get back in time enough for Ted to finish the engine .
For me, a trailer, or hauler just isn't an option, yet. If I want to bring it, I gotta drive it.
My most common problems have been pushrods and rocker arms. I have spare push rods and I'll have a set of rocker arms that I'll bring along. The only other things that have me slightly, unfoundedly, concerned are the ignition system and fuel pump, mostly because they're electronic/electric. I haven't had any issues with them whatsoever but if they do fail, I won't be able to get a replacement easily en-route. I am thinking about getting a higher pressure pump that I will install for the racing and cruising around up there, if I do then I can use it as a backup and I can always bring my points distributor and coil. I just don't want to bring a whole lot of stuff because it's going to be two guys, luggage, computers, cameras, and I'm picking up stuff to bring back. With the spare tire in the bed, there's not a whole lot of room to spare. But, I know if I have them, I won't need them.
My trip to see Reed and Bill earlier this year went real well. That round trip is about 2/3 one way to Columbus and my latest rocker arm issue occurred quite a few miles after that. So hopefully I will get there before something breaks!
The thing that upsets me is that it's always the new stuff breaking.
By Ketterbros - 14 Years Ago
GOOD LUCK to all, suspect Ted will be passing through my area soon on his way up north.. Again Good Luck to all
By LON - 14 Years Ago
Good luck, drive safely to all of you lucky people who will be traveling to Columbus this year. Sure will miss y'all! We will try to make it next year. The only thing that will stop us is money, stock market, election, and Global Warming! Have fun guys, give our best wishes to Barb and the girls. Live the Dream.
Lon & Lynne
Y-Guy Lon: I'll be flying YA'LLS colors with my Queenland tag....got my Cal-Tracs copies done to help my 60' foot times..shooting for 13's....Reed says 12's.. he's going to turn up the boost.....lol We will be thinking about you and Brad and hope to meet Lynne next year. Bill
I'm going to check things out next weekend. I have a set of original rocker assemblies, and spare pushrods. I'm bringing my points distributor and coil which I will have set up so I can use the Duraspark cap and rotor for a pretty easy swap if needed - all I had to do is to make a firewall pigtail for the hot wire and make a different coil wire to work with the male terminals on the cap and I'll bring a set of plugs gapped for the lower energy points ignition so I don't have to do that on the side of the road. I've ordered a higher pressure fuel pump which I'll get mounted this week to ensure that I can swap it quickly if needed. I may just leave it on since the carb manual indicates that 5 - 7 psi is optimal and I only have about 4 with the current pump. In either case, I'll have a backup. That should be all of the significant stuff.
If I have all of this stuff, then I won't need it, so I should be good.
I had an issue with the brakes last week. The pedal went to the floor Wednesday morning. The front brake reservoir was empty. It looked like a leak occured at the fitting splitting the line for the front brakes. I cleaned it up as best I could, filled the master cylinder, and bled it and now it doesn't seem to be leaking!!?? I never had anything indicating a problem until I got in it that morning and the pedal went to the floor. So I need to figure out what is up with that.
Having my new house makes all of this a whole lot easier, though. I don't have to drive to a friend's house and work in the sun anymore, rather from the convenience of my own garage!
We're pulling for you Charlie. You must bring pictures of the house and garage.
I'll have pictures. It's just an attached two car garage so it's tight but a whole lot better than what I had. Nothing fancy, yet. And no homeowners association!
