292 heads
http://forums.y-blocksforever.com/Topic60624.aspx
By 64 Tim - 15 Years Ago
Can you put different heads on either side of the block?  For example,  I have a blown C1TE head.  Do I have to replace it with another C1TE head?
By paul2748 - 15 Years Ago
You can use any YBlock head ( 54 excepted because of compatibility problems)and it will fit the block and intake. But you will have to deal with different valve sizes, different compression ratios, different port sizes.
By Grizzly - 15 Years Ago
Tim,
Explain "blown" most heads can be salvaged with repairs?
cheers
Warren
It is leaking from the side.
Leaking antifreeze
Tim,
Without seeing the head, that's a lot of corrosion to be leaking. It may be able to be welded. Check with a head shop or engine rebuilder.
A replacement C1TE head shouldn't be that hard to find or a set of more desirable heads. You can turn a bad experience into a positive by buying a set of G or 113 heads you'll gain some efficency.
cheers
Warren
