The factory piston with pin weight for the Y-Block pistons is expected to be in the 675-710 gram neighborhood. As a general rule, pistons on the light side of this will not necessarily require any extensive crankshaft rebalancing while pistons that are on the heavy side of this makes rebalancing the crankshaft much more preferred. With all that being said, it is still desirable to have the complete rotating assembly balanced. If not balancing the crankshaft, it will still be to your advantage to match balance the pistons with pins as well as the small and big end wights of the connecting rods.
Here are some past discussions regarding balancing just the pistons and/or rods versus the whole rotating assembly.
http://forums.y-blocksforever.com/Topic2688.aspx
http://forums.y-blocksforever.com/Topic20542.aspx
http://forums.y-blocksforever.com/Topic35212.aspx
Performing a search on this site will bring up some more discussions on this topic.
