ECZ 292 Y block with Mummert Supercharger Camshaft Break-in with Video
http://forums.y-blocksforever.com/Topic58339.aspx
By Daniel Jessup - 14 Years Ago
Let's try this out...can't get my video to show up here on the website...
(charley, sorry...tried to follow your instructions. Looks like photobucket has the same thing ...the above text is called their "flash" code for sharing on sites like ours)
ok, here is the link to the video on photobucket...
http://s249.photobucket.com/albums/gg208/danaxjessup/Y%20Block/?action=view&current=100_5776.mp4
EDIT: Charley helped me out, just scroll below! you can see the other two videos if you root around my uploads on there...
The story goes like this: purchased a Mummert blower cam from Jerry Henry. Installed new lifters and said cam last month, been working on projects and decided to button this one up for the display motor. Did the break in period early evening. Minor issues such as an oil pressure gauge that went out on me, stuck on 15 psi or so (thank you, Sunpro), Eastwood header coating burned off a little too much for my liking, oil pan leak I did not expect (crank flange and rear main seal cap dry on this one, go figure), and to top it all off, my JB weld radiator decided to pee all over the floor! Tongue What an ending. The cam sounds super, and the engine really responds and will rev pretty high. Didn't want to risk it too much with stock valve train though.
Here you go.
What are you? Houdini? w00t I have been trying to figure this thing out with the preview button for about a half hour! Tongue
I have got to post the video of the radiator springing the leak and spraying water across the garage..Hehe
EDIT: just noticed that at the end of the video you helped me with, Charley, that any user can click on one of the three other videos shown, and of course...that leads to the "post break-in video" Wink
By mctim64 - 14 Years Ago
Sounds good! Wink
All I did was copy and paste it.
When I try to do it in internet explorer, it doesn't work. I'm using firefox.
Charley, thanks for your help. I dowloaded the latest version of Firefox, but I cannot get the forum to come up on Firefox. The error message says that it may be because I will not accept cookies, but I double checked the settings and made sure I could accept any and all cookies, tried to reload the page, to no avail...go figure.
Any way that you could get the start up video up on there? Here is the flash player embed from Photobucket...
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid249.photobucket.com%2Falbums%2Fgg208%2Fdanaxjessup%2FY%2520Block%2F100_5775.mp4">
