Latham Supercharger for Sale
http://forums.y-blocksforever.com/Topic53676.aspx
By Oldmics - 15 Years Ago
Not mine but saw it on another Forum that I attend.
http://www.ford-trucks.com/forums/1025637-latham-supercharger-rare.html?s=c50e9e458968d7d64a78ba219986188b#post9772115
I"ve never seen such a critter before.
Oldmics
By MoonShadow - 15 Years Ago
The were created so you could run a supercharger under your hood. I don't know much about them but they used the old Carter side drafts like were on the scrubvetts and Y-block interceptor boat motors. I would love to get my hands on one but I'm sure I can't afford it. They are usually up in the $4000 range. Manifold looks homemade but they did stick out quite a bit in the front. Chuck in NH
Karol Miller ran a Latham on one of his Bonneville/Daytona Y blocks.  I think his 256" supercharged engine ran the same class as his unblown 301.
Seller is asking 3K plus shippin for it.
Oldmics
By aussiebill - 15 Years Ago
Oldmics (1/5/2011)
Oldmics
Boys, let me recount story of this same blower!! about 2 1/2 years ago it was for sale on ebay, i saved the pics for my archives. then i saw it again for sale and immediatley reconized it by the cardboard background, it was won by an australian with an ebay name something like "speedway%)* ?, thinking he may only use the blower on another type engine, i contacted him if he was indeed going to do that and i would be interested in the manifolds. i actually spoke to him and he had paid at that time by west union money order, which now is prohibited by ebay, and never received the blower and was trying with ebay to sort it out. I dont know what happened, but he was out of pocket, no blower and this "could" ????? maybe the same ploy, it is the same blower pics !!!! I,m not trying to derail this guys sale, but that was what happened!! Maybe some unscrupolus seller used this guys photo to create a fake add ,so Be wary! thats all. From my observations they came with fabricated intake manifolds.
These are some pics, the SBC pic shows the huge lower pulley that spins the allmost non existent top pulley to enormous revs, the blower case is made up of numbers of segements that lebgthen it, made for small displacement CI engines generally. regards bill.
By Rono - 15 Years Ago
I've never seen any thing like it either. Very interesting setup. Looks like it could be the forerunner to the roots style blowers.
Rono
It was actually an adaptation from the Roots type system. The idea was a low slung package to fit under modern hoods. Had a pretty good reputation for reliability. Chuck in NH
These are unlike the Rootes (not roots) English design blowers.  Instead of two spiral rotors running together to compress the air (Rootes), these Lathams use a series of stationary fins and rotating blades, just like a jet aircraft engine.
By winstoncupbandit - 12 Years Ago
I happen to have a vintage Latham supercharger with the 4 side draft carbs and pulleys. I also have the old but brittle charger belt. I got it from my father who passed away years ago. It's been sitting in my garage for years. Looks pretty cool and wild looking. Really don't know what I'm going to do with it Haven't figured that out yet.
By bird55 - 12 Years Ago
Axial type was the term as I recall?
By Talkwrench - 12 Years Ago
http://forums.y-blocksforever.com/Uploads/Images/4b3271af-e71c-4a2e-a875-3715.pngIt reminds me of an early Australian supercharger from NORMAN . Note the expanding fins! http://forums.y-blocksforever.com/Uploads/Images/ab9be94f-dade-4f4a-b187-fcd6.png
By NoShortcuts - 12 Years Ago
Hmmmm...
From the web site www.axialflow.com a company making axial flow supercharger units today…
HISTORY
The first use of axial flow compressors for automotive supercharging was by Norman Latham of West Palm Beach Florida in 1956. This unit was known as the Latham Supercharger and was sold until 1965. These were built with a sheet-metal blade installed into a ring and locked by another ring. Very clever way of getting a wing into a disk. Trouble was there was no aerodynamic shape and the time to build was totally unacceptable.
These were made for almost all cars being produced at that time. They were supplied with Carter one barrel side draft carburetors in two and four carb setups.
There were over 600 produced. Most are still in running condition and sell at a premium on the vintage car market.
The Latham company was sold to Richard Paul in 1982.
From the 1959 book, ‘The Complete Book of Hot Rodding’ by Robert E. Petersen and The Editors of Hot rod Magazine published by Prentice-Hall, Inc.
Chapter 11, ‘Supercharging for Increased Performance’, page131, second column…
Latham axial-flow superchargers are available for both road use and competition. These superchargers differ from conventional centrifugal and positive displacement types in that their only moving part is a long rotor encased in a tubular housing. The rotor runs on ball bearings and it is rotated by the crankshaft by means of a flat belt. The outer diameter of the rotor is fitted with a large number of blades, as is the inner diameter of the housing.
As the rotor is rotated, air moved in the housing by the blades on the rotor creates a low pressure at the front end of the housing and a high pressure at the rear end. Atmospheric pressure outside the blower forces air through the carburetors bolted to the front of the housing to compensate for the low pressure. As the air passes through the carburetors,fuel is mixed with it and then the fuel/air mixture is forced to the rear of the housing and into the engine’s intake manifold.
When Latham blowers were first made available they were designed to use the stock intake on the engines on which they were installed. Performance with this set-up wasn’t too good because of the restriction to air flow create by the manifold but this condition was corrected at a later date by providing special manifolds with the blowers. These manifolds have adequate flow capacity to handle the air displaced by the supercharger, enabling the boost created by the blower to get into the engine. Good performance has been recorded at several competition events with this new set-up.
Note: On page 130 there is a picture of a 45 degree down front-on-view of an early ‘Bird engine compartment with a Latham unit installed. Perhaps the hood was removed for the picture taking. The pictured Latham unit has two carburetors mounted horizontally at the front of the supercharger parallel to the radiator. Flexible tubing is attached to the carb air horns and makes a 90 degree bend back toward the firewall seemingly supported just above each Ford exhaust manifold. The flexible tubing junctions into helmet-like air cleaner housings that are also horizontally positioned and end about midway between the tip of the wing and the head of the bird on the aluminum ‘Bird valve covers.
No shortcuts,
thanks for the history info. I know I've seen these in past magazines mounted on birds a long time ago. Possibly the one mentioned in your reference. Wish I knew where those pics are. I think it was in small book like mechnix illustrated.
Hold It, I just found it. I'll try to get pics up soon.
By Louie928 - 11 Years Ago
Do you still have the Latham? For sale? I used to have one on my '57 T'Bird.
By kbee - 11 Years Ago
Thanks No short cuts,
You reported and accurate history of the Latham.
I'm Norman Latham's son-in-law and know it well.  Will post some pics later.
By DryLakesRacer - 11 Years Ago
A friend is currently finishing a 34 chopped 3 window with a Latham flathead. They are very cool. He made many of the brackets and stuff to make it work. As said Karol really hauled the mail with his 56 Vic using one...
