1951 & 1956 Ford F1 & F100 parts
http://forums.y-blocksforever.com/Topic52044.aspx
By Californiadreamin - 15 Years Ago
For Sale............
NOS rear end gear sets,2 axles and cover,down draft tubes,oil filler tube with cap,flatty timing covers, oil filter cannister with mounting bracket,good used flatty crank and rods,cam,lifters,valves,keepers,rings,2 used water pumps,one pair new water pumps,2 new drive side water pumps,2 powder coated steering column assemblies with mount brackets,radiator core support,real nice front fender extension,2 new door hinge mirrors,3 new emergency brake cables,used emergency brake handle,new under dash wiring harness,drive shaft with new joints,powder coated trans bell housing plus a nice 1956 F100 trans cluster gear.
New F1 rubber seals,bed lacing,cowl lacing with nails,top of trans to cover seal,glove box rubber bumpers,hood rubber bumpers,cab to chassis and bed mounting kit,fender welting,1956 tail lite assemblies,F1 front shock mounts,U bolts and good used brake shoes,51 hood side trim pieces,51 heater with core no motor,51 under dash wiper arm assembly with pivots and escutcheons,51 interior visors,51 door hinge pins,NOS 1956 steering box sector,pitman arm,bushings,gaskets.Have other items not listed including a 1956 SW cab and 1956 BBW cab plus a complete 1956 BBW rust free truck project Can provide pix and prices for what you need.
By BFOOTER03 - 15 Years Ago
Do you have a 56 Radiator Shroud by chance?
Yes I do..
By SteveF100239 - 15 Years Ago
I emailed you about the rearend gears. Looking for something close to 3.52(4) to replace my 3.92 in my 55 truck. Would what you have fit mine?
Steve
By TN 52 F1 - 14 Years Ago
Do you have an emergency brake handle that would fit a '52 F1?
Thanks,
By ronierogers - 14 Years Ago
hi there i am ronie a new member in here kindly update your list. i need some of the parts in there i you could also post some pictures of that hood the better. i have a paypal for the mode of payment. please let me know as soon as possible. also pm me the price or post it in here so i can compare the price at discount auto parts. thanks.
By Mgodsy - 14 Years Ago
Do you still have the big rear window 56 cab?
By PF Arcand - 14 Years Ago
Where are you shipping from? Presumably somewhere in CA?
