Take off parts
http://forums.y-blocksforever.com/Topic51779.aspx
By YellowWing - 15 Years Ago
Now that the work on my 56 is coming to an end there is a bunch of parts I need to get rid of so I have room to move around here. Everything is in very good condition and was working when removed from the car a few months back. I am not trying to get rich off this,make me a fair offer and pay the shipping and it's yours. Anything I still have in a week is going with a friend to Good Guys with instructions not to bring it back. I would prefer someone on the board should get them rather than strangers. Thanks for looking and hope there is something you can use. If needed you can arrange for pick up at Good Guys in Scottsdale next week. Mike
All parts came off a 56 with a 312 and four barrel carb
Ford-o-Matic trans and bell housing ( has rebuild date of 2004)
Flex plate and torque converter for same
Rod and end for kick down linkage
Front steady rest
Generator and brackets
Starter (almost new)
Stock cam and lifters marked for location ( looks to be just broken in)
1.43 rockers (very little wear)
Valley cover
Distributor
Exhaust manifolds
Radiator ( good condition and was not leaking when removed)
4 hub caps original with red center emblem and the ford crest (very good with light scratches due to age and emblems that are clear with no crazing)
original oil bath air cleaner
T-Bird style chrome air cleaner ( probably a reproduction due to almost new condition with just light scratching wrom being wiped off)
Fuel sender (original)
Full gauge set,no panel (some fading on the orange and gey, all worked except the clock)
I forgot.
Original Midland brake booster(don't know if it works it was left in place for looks only)
Dual master cylinder (was installed when car was converted to front disc brakes, no booster)
Original fuel pump with vacuum pump on top.
Original damper ( has a speedy sleeve on it)
Bolt on single groove pulley for above damper (for power steering)
By Dave V - 15 Years Ago
I might be a little late. Hope you didn't get rid of your parts yet. I'm in need of the power steering pulley which bolts to the crank damper. Mine is a 56 292 which I assume is the same as the 312. Dave 262-903-3880.  Thanks
Sorry Dave, sold it yesterday for five bucks. Mike
By hotrodnailhead - 15 Years Ago
I saw this add too late! I was at GG on saturday and I went through the swap... I'm looking for a 12V generator and brackets.
I still have the 12v generator and brackets. It was at GG on Sat but did not sell. Mike
By oldcarmark - 15 Years Ago
Mike:Sent you a PM today.If you dont get it let me know SAP.Thanks Mark
Just spoke to my friends that took the parts to Good Guy's for me and they tell me the oly pars left are the transmission,valley cover, 12v generator and brackets. Mike
What do you want for the Generator and brackets, and can you ship?
I just looked up Rimrock AZ, and it must be beautiful out there... but I think I'd need to put chains on my hot rod.
By Gary - 15 Years Ago
I am interested in the "rod and kickdown" linkage.  gadams2@bellsouth.net. 205-706-7614
thanks, Gary, Birmingham, Al
