WTB fuel gauge
http://forums.y-blocksforever.com/Topic50025.aspx
By kevinwalshe - 15 Years Ago
I was working on my dash today and as I was loosening the nut on the back of the gauge, it snapped leaving the stud just hanging. If anyone has one or if anyone has an alternative way to put in a gauge, let me know. I already have put in a brand new sending unit and it was working until today.
Kevin
By carl - 15 Years Ago
Do you have a 55 or a 56 merc. 6volt or 12 volt.  Carl   Ohio
By 55Birdman - 15 Years Ago
I have a complete gauge cluster for a 56  Ford car I can let go . Dont want to break up the set . Can send pics if you want to see it. wpccgrad@hotmail.com
Carl - It is a 55 merc. It was 6 volt but I switched it over to 12v and used a Runtz reducer which worked very well until i snapped it.
Earl - Just emailed you
Earl   So you need the 12volt gauge?     Carl
Kevin needs the gauges. I have a set for a 56 car.
By oldcarmark - 15 Years Ago
Are Merc and Ford gauges the same!
Mercury and Ford gauges themselves may be the same, but it is definitely not a direct bolt in as the Mercurys have all the Oil/fuel/volts/temp above the speedo whereas the fords have two above and one on each side of the speedo. I can use either 12v or 6v. If I use a 6v gauge, I will still have to use the reducer which doesn't bother me since it worked fine before.
Do you have one Carl?
Kevin
Yes i have the gauges,they are from a 56 Merc so they are 12 volt.I have all 4 from the cluster if you need them.56 ford gauges are not the same.E mail me at CL56VIC@YAHOO.COM  Carl  Ohio
If you do use a 12 volt gauge dont forget the other gauges still need the voltage drop.
