Distributor Advance Curve Problems
http://forums.y-blocksforever.com/Topic49569.aspx
By peeeot - 15 Years Ago
I have attempted to adjust my distributor (purchased from Advance Auto Parts) to fit the specification given in the factory manual using a tachometer, vacuum pump, and timing light.  I have obtained results that are at least close to specification, but something is wrong.
If the car is idling in park and I slowly and gradually increase the throttle, the engine is smooth and fires evenly until around 900 rpm all the way up to something like 1400 rpm.  In that range, it misses, shakes, and is generally unhappy.  It seems to improve at higher rpms.  If I accelerate through that same trouble range with the vacuum advance disconnected, it does not miss or shake.  The vacuum advance is giving far too much advance at those speeds for an unloaded engine.
I have never known an engine in good tune to miss and shake during any reasonable range or load of operation, or, specifically, when slowly acclerated at idle in park.  So I conclude that something is wrong.  But it does not demonstrate the same problems when driving.  It is generally smooth and responsive.  At high road and engine speeds, say 70mph (3k rpm) it feels like something is off though.
The vacuum pickup on the carb (it's original, autolite 2100) is above the idle screw hole but below the transition holes, so it sees manifold vacuum almost the moment you ease off of the idle stop.  What is so puzzling to me is that all of the pieces of the system seem to be set according to their intended design, yet the actual performance of the system is flawed.
Any thoughts about what, if anything, is wrong here?
The roughness is probably due to too much advance at that speed.  Are you sure the damper hasn't slipped and giving you a false tiiming reading?
What John said about the damper, but could also be carb related. You may have a problem as the carb transitions from idle.
By oldcarmark - 15 Years Ago
How much is the vacuum advance advancing the timing?Should be in the range of 6-10 maximum.The vacuum can is adjustable through the nipple using an allen key.I believe counter clockwise reduces the amount of advance but you will see quick enough as you adjust it.Total advance,initial+vacuum+centrifugal should be no more than about 44 total.The distributor centrifugal advance could be 26 or 36 depending on which slot in the cam assembly is engaged in the stop post inside the distributor.You will have to take the breaker plate off and see which it is.It sounds to me like the vacuum advance is giving too much advance.Something I didnt realize until I started playing with my distributor is this.Vacuum advance comes in at low RPM when vacuum is high.Comes back in at high RPM cruise conditions when engine vacuum is high again.As an example-if initial is 10 BTDC,vacuum advance is 12 maximum and distributor is 36 you will have 58 total advance at high RPM criuse condition when vacuum is high.Way too much whch will cause the engine to missfire.Have a look at the vacuum advance and see what it is advancing the timing by at just off idle as you are using ported vacuum source.You can also use direct(non ported) vacuum source if there is an outlet somewhere on the intake for fulltime vacuum.This will advance timing as soon as you start the motor.Hope I dont sound like a Know-it-all in this post but this is what I learned while working on my own distributor problem awhile ago.One other modification I did was install a pair of light centrifugal advance springs from Mr.Gasket(about $5.00 for kit)which gives quicker advance.Doesnt change total advance just allows quicker advance.Makes a noticeable difference in power.
By GREENBIRD56 - 15 Years Ago
The advance "can" on the new distributor can supply 10° distributor/20° crank at 15 inches hg. Depending on where you set your initial advance with the vacuum line disconnected / plugged - you could be considerably over-advanced. Chances are pretty good the replacement distributor came with its "can" set wide open. Most of the newer versions can be (gently) adjusted with a 3/32 Allen wrench inserted through the vacuum nipple. Older models with the hex nut on the line entrance have to be disassembled and shimmed.
Where have you set the initial advance? Your new distributor will not have come with the same internal settings and springs.
Greenbird56, you are quite right, the distributor came adjusted for who knows what engine and I did not trust for a moment that it was calibrated properly for my engine, thus the efforts to adjust it.
Everyone who suggested that the spark is over-advanced is definitely correct.  I'm just not sure why it's over-advancing.  Let me give some additional detail.
First, this is how I have calibrated my distributor.  I looked up the centrifugal specs in the manual.  It calls for x-y* advance at z rpm.  I have taken these values to be DIST degrees at DIST rpms, so I doubled x,y, and z for each data point.  With the vacuum advance line plugged, I then would rev the engine to the spec'd speed and use my timing light to check for the spec'd advance increase over initial.  I did this mainly for the low-speed spring, because my tach only goes to 2k rpm so I just sort of assumed the high-speed spring was where it needed to be BigGrin
Then, to set the vacuum advance, I idled the engine as slowly as I could to prevent the increased engine speeds due to forcibly advancing the spark from bringing the centrifugla mechanism into play.  The manual specifies x* advance at y "hg vacuum, and again I doubled x.  Using my hand vacuum pump, I supplied the spec'd vacuum, then looked at the advance.  My advance can is NOT the allen key kind, and as it turns out the spring rate of the supplied spring was too soft and would never produce the spec'd curve, so I obtained several other springs from the hardware store and found one that had almost exactly the desired rate.  The washers move the curve up and down, and ultmately I got all the data points comfortably within their ranges.
I have the initial advance set at 8* by the damper.  Who can say whether it has moved?  I chose the 8* mark partially on assuming the damper hadn't moved and partially on the way the engine ran.  It would run faster at idle if I advanced it more, but I did not want to max out initial advance.
I should also note that at hot idle, there is not enough vacuum to the advance can to move it, but just a touch off of the hot idle stop i get 15"hg.  So, around 1000 rpm, the timing light show over 30* advance--waaaaay too much.
The way I see it, either my calibration method is wrong or this thing was designed this way--and I'm more inclined to believe the former than the latter.
Oldcarmark, the centrifugal advance is set to an 18/36* maximum, and the vacuum advance maxes out at about 12/24* (dist/crank degrees).
Thanks so much for your help so far everyone!
That cam can be switched to the 13L slot which gives 13/26 crank dgrees.The other end of the cam should be 13L.If you stay with the 18/36 slot you will end up with over 50 BTDC at highway cruise speed when you ad all 3 factors together initial+centrifugal+vacuum.Steve(Greenbird56) likes to use the 13L slot not the 18L one.I have mine on the 13L slot.
The use of the 18°/36° is going to be way too much total mechanical advance - add the 8° initial you mentioned and we are at 44° mechanical - and the engine won't like that a bit.
With a little disassembly - and you've been down to that level already - you can swap the advance mechanism over to the lower setting of the advance, is it a "13L"? That's 13° distributor/26° crank. That plus an initial of 10°-12° will net a maximum mechanical of 36°/38° which is close to correct for one of these stock engines. Mark is right - use the proper springs to get all of the 36°/38° at between 2500/3000 rpm (with vacuum advance disconnected and plugged). The engine should be both run-able and tune-able with these spec's and no vacuum advance.
To get economy you will want some vacuum advance added to the engine at periods of low load - cruise. You will find that with the quicker mechanical curve it works best to restrict the vacuum advance at the crank to something like 7°/8° so the total available at cruise / low load over 3000 rpm won't exceed 43°/46°.
I have found that putting an orfice in the vacuum line to slow the speed at which the vacuum pot makes its additions and subtractions of advance - is extremely beneficial to driveability.
The 18L/36° slot is provided for use with an engine set up at 0° initial advance. You won't like the way the engine runs with that sort of initial advance - it will have a very hot idle and drink fuel.
I just wanted to make a suggestion.Are the other style "allen key" type advances not much easier to setup?I am surprised the rebuilt distributor came with the spacer-spring type advance.Dont see them much anymore.Why not switch advance units and make it much easier to tune?By the way,you can do better than "factory" specs to really dial in the distributor for your particular setup.Don't get hung up on trying to duplicate what original specs call for.The Y-block likes a little more initial advance and setting up the advance curve can do wonders for the way it runs.Something else to check.When I put my rebuilt dist. in I was having trouble with the timing marks being unstable.The timing marks would move back and forth when checked with the timing light.After much aggravation and not finding the reason,I noticed there were specs listed in the shop manual for dist. shaft endplay.How far the shaft can move up and down in the dist. body.Not side play-endplay.Specs are I think .026-.050 measured between the bottom of the body and the retainer part on the shaft.Mine was over.100-more than double maxpecs.I purchased a washer kit from Mr.Gasket which gives 3-4 thin washers yo shim between body and collar.I got mine down to minimum-.026.You have to take gear and collar off.What was happening was the  shaft was riding up and down due to the action of the cam gear on the distributor gear.timing would change  as the cam went up and down opening the points.Problem fixed.You might check yours while you have it out.Specs are listed in shop manual.
By 62galxe - 15 Years Ago
Does anybody have a part # / brand for a replacement vacuum advace can. Sorry for the hijack but this is exactly what im dealing with. My advance allen stripped out.
I have just thought of something which I think may be the real source of the problem.
I have been studying the specs listed in my manual and in the manual for my sister's 1970 Dodge Polara with a bone-stock, original 318.  Both manufacturers call for a very similar advance curve, and one in which if you add the max advance limits at the crank of each component of total timing, you get a number in excess of 60 degrees at the crank.  When I observed the advance behavior of the Polara, though, I noticed that I was able to increase engine speed a couple hundred rpms before a vacuum signal to the vacuum advance ever occurred.
Further study of that manual showed conclusively that the vacuum advance pickup port is ABOVE the throttle plates when they are resting at idle position.
Is this supposed to be the case for the autolite 2100 as well?  Because I have a low vacuum signal even with the engine idling at 600 rpm in park.  The mixture screws are happiest 3/4 turns from lightly seated.  I am wondering whether the throttle plates might be misaligned in the throttle shafts.  I have messed with them so it is certainly possible, though I'm sure I tried to seat them properly before.
By Ted - 15 Years Ago
Does unhooking the vacuum advance line and slowly bringing the rpms up eliminate the ‘missing’ you’re experiencing?  If so, then hook up the line and drive the car.  You may find that the car drives just fine with the ‘missing’ you were experiencing in neutral or park now gone.  Under a load, the advance curve will react differently than checking it when speeding up the engine in a no-load situation.
peeeot (9/11/2010)
Is this supposed to be the case for the autolite 2100 as well? ......
Yes.  At idle, the vacuum port in the carb throat for the distributor is just above the throttle blades at idle.  That means effectively no vacuum signal to the distributor at idle.  As soon as the throttle blades are opened enough to expose that particular hole to the lower portion of the blades, a vacuum signal will be generated at that hole.
62 galxe!Kenny,I just had a look at Rockauto.com for a distributor advance for 62 Galaxie with 292.Standard # VC-31 or VC-25 are listed.These are the Allen key adjustable type.The instructions will tell you to turn the adjustment screw the same # of times as your original unit.Because yours is damaged you will have to set it from scratch as described in this post.Check your local parts supplier.They should have a listing by vehicle application if they dont sell Standard parts.
Ted, you are right, while driving I do not notice the missing and shaking at low engine speeds that I get in park.  With the vacuum advance disconnected in park there is no missing either.  But just because an engine isn't missing doesn't mean it's advance curve is set right, and I have taken the miss in park as a clue that some aspect of tuning (most likely advance curve) is off.
The way things are now, the vacuum pickup port in the carb throat is approximately even with the throttle blades at idle.  Looking into the carb, I can clearly see the uppermost of the two idle transition holes above the throttle blades, but I cannot see the lower transition hole nor the advance pickup port.  Yet, as is, idle speed is just 600 rpm.  I can't shut the throttle plates much more without stalling the engine.
To anyone with an autolite 2100: where are your mixture screws set?  Are both idle transition holes visible above the throttle blades, engine idling?
By Talkwrench - 15 Years Ago
This is great stuff, and Im looking at this at the moment.
Mark, can you give me the link for those springs you got .
Steve, Can you explain the orifice? can it be used to lower the vacuum?
AT this point I have set mine at [ with no vac] 13* initial , 28.5* @ 2750 RPM, 35* @ 3300RPM.
with vac 51* @ 2930RPM, 53.5 @ 3280 RPM . I have no pinging. seems I need a bit more workBigGrin
The Mr.Gasket # is 925D.2 springs in the kit.You have too much total advance.You need to go through the steps suggested as far as checking which cam# is engaged on the stop.I believe you are using the 57+ distributor.Correct?Initial advance on mine is 10 BTDC,8 degrees of vacuum advance adjusted on the can and the cam set on the 13L slot which gives maximum 26 degrees centrifugal advance at crank. 10+8+26=44 maximum advance.All in under 3000 RPM.With the total advance available on yours it may not ping but at high criuse condition it will likely "surge"or miss because timing is too far advanced.
Its a 59 dizzy. off the top of my head a V8 normally runs a total of 36* total mechanical advance, so I should be able to run it without the vac advance ok anyway.. HAd to do that to my Cuda as MOPAR vac advance are crap.. goes ok.. Look forward to more on the topic and sorting it out.
Actually the vacuum advance is important for low end performance and fuel economy.You would only run full centrifugal in a race car OR a street vehicle with extremely radical cam.
Looks like I have the spacer type vac advance, so how do these adjust??
Greenbird.. CAn you give us the rundown on the orifice ...? How what and where...Wink
The advance canister shown below (disassembled) has two items that can be adjusted.
After you unscrew the hex cover from the can -there are shims that preload the spring. Adding or removing shims changes the advance travel position versus vacuum applied. If the spring preload gets up to a point where the vacuum can no longer overcome the spring sufficiently to reach the mechanical stop - then it would also have the effect of limiting the total vacuum advance available.
The fiber tube is factory sized to limit the travel of the unit at a particular amount. By installing a longer tube for instance, the total travel would be limited. Both of these items are subject to experimentation.
To run "hard lines" on my outfit, I used brake tubing formed to fit on the manifold - roughly run like original. Its attached to the carb and the distributor with rubber tubing at both ends. At the distributor end - I inserted an electrical "butt splice" (red plastic cover) - and crimped it until the system behaved the way I wanted it to. Others have used a solid piece of brass/plastic/steel and drilled holes to get it to behave properly - try a 1/16 hole and see what that does for you. When mine was working to suit me - I pushed the rubber over the butt splice enough to make it invisible.
I have been reading up on advance curve setting, both in this forum and elsewhere.  Most of the info is for maximum performance, though I am more interested in economy.
Anyway, I was wondering, why do we want all of our mechanical advance to come in by 3500 rpm?  If one desired to take the engine on up to 4 or 5k rpm, wouldn't the optimum spark time at those speeds be earlier than that of 3500 rpm?
Is there a maximum limit to advance after which more is detrimental, even as engine speeds continue to increase?
I believe you will find that the optimum mechanical advance limit for a pretty much unmodifed y-block is going to be around the 36°-38° mentioned earlier. More efficient higher compression engines will use less - less efficient engines might use more. This value applies to an engine under load - high throttle opening, low to no vacuum - passing uphill etc. That is the maximum we are talking about - the upper advance limit when the engine is heavily loaded. Even a "gas economy" rig has occasions where full power has to be available - without injuring the mechanical parts.
The "early" advance curves we have described are used to take advantage of the additional torque available - low in the rpm band - when the spark advance is optimized toward building maximum cylinder pressure. It takes about one millisecond to light the fire - as the revs go up the spark initiation point has to get further and further ahead - but you are also moving toward less and less compression of the mixture (away from top dead center on the front end, the piston is rising up the bore). A limit is reached where "enough is enough" - and you can't get any more torque advantage out of the quicker spark curve. The old "Y" cylinder head combustion chamber design is not the best - flame travel isn't like a GM "fastburn" by any means - its 50 year old technology.
This low end torque advantage - you will feel it in the seat of your pants - and it could very well increase your fuel economy because the engine will accelerate the vehicle without as much throttle opening. Thunderbirds like mine are pre-programed from the factory to take off in second gear of the Ford-O-Matic (low is basically a manual selection in ordinary driving). Your two speed might have a better low than I've got - in second. One of these T-birds in poor tune stumbles away from a traffic light trying to transition from idle under heavy load - it's tuned right "or else". When I changed from the "Load-O-Matic" to a '59 distributor (using a manifold vacuum source) - it was like taking 500 pounds out of the trunk. Uses way less fuel too.
Vacuum advance has the effect of leaning out the engine when vacuum is high - low load, slight throttle opening - no call for power. Even in this state - there is a limit to how effective additional advance might be. If the engine has been fitted with a more optimal mechanical advance curve (a higher number of degrees at a slower speed) then less vacuum advance is permissible - to keep the total within bounds. This leaning effect gives better economy - and when the throttle opens a little or a lot you are going back down toward the mechanical limit. About the only way you can get the maximum total spark advance in most vehicles - everything summed (initial+centrifugal+vacuum) - is a high speed downhill in the mountains - with the throttle closed - using the engine as brake torque. You aren't making power in that case - you are using it.
Hope this helps out a bit with the "logic" of the systems as they are applied to our street engines.
Here's another question that I haven't found any info on the internet about:  at what point (engine speed and advance) should the mechanical curve switch from relying solely on the low-speed spring to both the low and high-speed spring?
By aussiebill - 15 Years Ago
GREENBIRD56 (9/13/2010)
STEVE, again your knowledge of all things electrical was explained so well in this quote, very interesting and informative. Best regards bill.Smile
Inside my distributor I have 18L and 21L slots.  I cut the end off of a small hose and fit it snugly over the limiting tab in the 18L slot, and based on my test results it gives 28* of crank advance. With the springs that came with the distributor, the primary to secondary spring transition appears to occur around 1500 rpm, perhaps a touch earlier, at 22* mechanical + initial.  The combined weight of the springs brings total advance of 38* (crank) at around 3600 rpm.
With the distributor set as is, vacuum advance disconnected, it gets unhappy around 1500 rpm but clears up as engine speed increases.
When attempting to set the mechanical side, will road tests with vacuum advance plugged show me whether I'm getting closer to where I want?  I mean, should I make the car run and drive the best I can with the vacuum advance capped off first, then deal with the vacuum side when that's done?
Just wanted to post a final follow-up.  I am finished tuning my advance curve and am pretty pleased with the results.
I bought the Mr. Gasket kit 925d.  It contained two identical light springs, a bit lighter than the primary spring I was using to begin with.  I ended up using one of these new springs in the primary position and the original secondary spring.  Any other combo brought all the advance in too early, resulting in spark knock.
I have my vacuum advance limited to 6 degrees.  Even that much is enough to produce some irregularity revving the engine in park in the 950-1400 rpm range, but it is better than it used to be and I notice no negative side effects driving.  The car is quite responsive even without the vacuum advance, and WOT does not incur any spark knock.  It's still not what I'd call a fast car, but it's faster than it was, which is nice when you need it.  I don't know how fuel economy has been affected yet.
Anyway, I'm gonna take it as it is!  Thanks once more for all the help and wisdom along the way.
