Custom Stake Pockets
http://forums.y-blocksforever.com/Topic48472.aspx
By grovedawg - 16 Years Ago
So, I didn't like the straight, plain Jane stake pockets. Taking cues from the earlier F1, and the 54 Chevy I decided to make my own. Never done it before, and I'm sure it's probably simple enough to figure out. I just thought I'd throw a few pics up and maybe get some feedback. I started out with a lot of different outlines on cardboard until I had just the right pattern. I cut some 16 guage steel (I like thicker stuff) for the front of the stake pocket. I built a buck out of two 2x4's glued together. I cut the patern into the buck on a table saw. Then I tried to bend the metal over a large 4 1/2 pipe I had. After a while I just beat it out on the concrete until it fit the buck.
I basically had all four of the "faces" of the pockets done. Then I spent about an eternity cutting out 8 square sides. I stacked 4 of them together, traced the pattern onto the outside of the 4 pieces, c clamped them together, placed them into a vice, and cut them out with a sawsall. Very carefully. Then I clamped them over the original stake pockets, tacked welded them. I made sure everything was still Kosher. Then I burned them in. After another little time of carefully grinding the welds I think they came out ok. I drilled all the holes, and a few extra to rosette weld them to the original pockets. Then I rosette welded them to the sides of the box. Final pic shows how they turned out.
By Ol'ford nut - 16 Years Ago
They look great! Just to ask what do you have planned for lights?
Now you have to do something "special" with a tailgate. IE: no chains, hidden latch.
Keep up the good work and post them pictures.
Excellent work!
By JJ - 16 Years Ago
Nice jobWink
Ol'ford nut (8/16/2010)
I'd love to French some Caddilac lights into the rear fender wells, but I'm still undecided. I've also been planning on some kind of custom rear bumper as well. Maybe a roll pan. I don't know on that either.
But I'm for sure going to go with hidden latches. Smile
I'll post more pics as I go.
By BFOOTER03 - 16 Years Ago
Nice work.  They look good.  I'm voting for a customer maybe with tail lights???
By jonnireb - 16 Years Ago
Looks great Dawg,
there's nothing like making some custom pieces for your
truck. Keep us up to date on your truck.
