First round of testing of the new aluminum heads is now complete.
http://forums.y-blocksforever.com/Topic44066.aspx
By marvh - 16 Years Ago
Great test Ted. Very nice torque and HP curve John. Top quality there fellows and congratulations.
Ted I was reading on you first post about the mule engine and (quote) The engine used for the test is a +060 over 312 with the cast flattop pistons 0.025” in the hole and stock G heads that had only a good valve job with hardened seats installed and a 0.025” mill to clean up the deck side of the heads.
Being the pistons were .025" in the hole did you have to mill the block to get the .025" clearance. If the block was milled did you have to remove material from the new heads intake surface to mate the intake manifold properly or is there enough freedom to install the intake without milling that surface.
marv
Ted (Quote)On an unmachined and stock Y block and using the stock cylinder heads and composition gaskets, the heads will sit ~0.020” higher than stock if no milling of the heads or decks takes place.
Thanks Ted for that info, that what I was looking for as an engine I am working on has had the deck shaved to get a .020" clearance above the replacement pistons while using steel shim gaskets (.021") to get ~.040" head to deck clearance.
Can you run less a piston to deck clearance with aluminum and still not have detonation issues.
Just looking what changes needed if I put on a set.
marv
By DANIEL TINDER - 16 Years Ago
jepito (5/14/2010)
What are the chamber sizes of the two heads tested?
I am also interested in what % of power increase could be attributed to higher CR?
By Hollow Head - 16 Years Ago
What are the Hp and torque numbers at the same rpm's as tested with G heads? I know the new ones are better at higher rpms but are they waste of money at the lower rpms Cool?
Can we see some graphs to compare?
By PF Arcand - 16 Years Ago
John: Possibly this has been covered before but I've not seen it. If your new heads are installed on a 292 or 312 with stock pistons (lets assume the block is not over bored more than 0.020 thousands) in a non decked block, what will the approximate compression ratios be? Thanks.
By bird55 - 16 Years Ago
Fordy Guy (5/17/2010)
Love the phrase "get 57 supercharged power without the supercharger".If I can come up with the money to have JM build me a block,I will get me a set of aluminum heads too.
I had no doubts the performance numbers would be good. It's the phrase… "if I can come up with the money" that's what I'm thinking. :Wink
By Daniel Jessup - 16 Years Ago
Smooooth Hold on to your steering wheels, these things are going to give an awesome ride!
Ted, that is great baseline info for these heads! Can we automatically assume that these heads are going to be used on your EMC motor?
John - Hats off to a job well done! Let's hope Edelbrock will remain in there and do a good job for the Y block.
I believe the mag said $2049 if you ordered by the middle of May. I just got my mag two days ago, so I think JM was believing that the magazines would all be in the hands of prospective buyers well before the middle of the month. Unfortunately the USPS got them out a little slowly...
By Don Woodruff - 16 Years Ago
Great results. I would have estimated 320-330 horse. Not knowing the specifics of Teds engine I could not put it into EAP.
If an engine were built specifically for these heads with 0 deck, about 10.5 cr and possibly a bit shorter, higher lift cam and mildly ported heads 350+ horse power may be possible with a very streetable "Sunday go to Meeting", not racing, engine. This would back up my paper engine very closely. John you did good. Thanks for the info Ted. The ported heads should shine on your Engine Masters engine.
This from Teds original Post
With the 2” four hole carb spacer, the aluminum heads outperform the iron heads at all rpm ranges.  With the 2” tapered carb spacer and below 2800 rpms, the iron heads are only marginally better in torque than the aluminum versions, but after 2800 rpms, the aluminum heads simply run away from the iron versions with the best peak horsepower numbers.
 I believe this indicates it is about a wash below 2800 rpm but above 2800 rpm the Al heads are superior with this combination.
A guess that with a shorter cam, a smaller carb, the advantage of the Al heads may move a bit lower in the RPM range . Ted is the expert though.
I have built FE engines with "0" deck and shim gaskets with no problems. These were with old style combustion chambers. I would not anticipate problems with the new chambers. Ted has undoubtedly built engines with new combustion chambers and can answer the question.
I ahve not yet recieved my "Y" block mag any one else recieved theirs?? I only live about 50 miles from Bruce, maybe I'll have to drive down.
The strong probability is that the 3x2 setup would fare  no better than the single 4 on the iron heads.
I do not recall the flow on those carbs but the three carbs combined is not as good as the single 4. The heads were the cork before but with the 3x2 the cork will definitely move to the carb/intake.
By Y block Billy - 16 Years Ago
Wow! Great job "John" and "Ted"
Ted, Wouldn't the push rods grow maybe .001" after warm up? we always used the calculation of .003" of growth per foot of material (steel and Iron) for every 100 degrees above ambient temperature for the equipment I set up around the globe. Also I know that the aluminum grows at a much faster rate, the number 1 cause of snowmobile/dirtbike/four wheeler piston failures is the fact that people don't let them warm up before reving them up and the piston grows faster than the cylinder and they get a cold seizure.
I don't have handy the exact growth of the aluminum versus the steel for the same temperatures, but as the steel catches up, might it change that figure?
Thanks for the clarification Ted, It was the net expansion I was thinking about.
Ted/John,
What are the flow numbers for the intake/exhaust for these heads out of the box versus the g's and where did the biggest improvements in flow come from? Opening exhaust port? changing angle of lower intake port to valve opening? combustion chamber shape and size ect. ect . ect. ?
I will then be curious as to the flow numbers that can be acheived once you guy's start porting them.
By aussiebill - 16 Years Ago
Hollow Head (5/15/2010)
Seppo, i initially wondered the same thought, re the Hp @ same RPM and figured the hp or torque nosed over at those rpm,s round the 1st heads results? ted will know for sure.
And with the growth rate on the new heads,that amount Ted mentioned is great point, so initial settings can be allowed for. For all my time rebuilding most earlier engines, i,ve allowed .002" cold set and when engine is ran, its nearly spot on for clearance. so this new figure for our new heads is a big help. regards bill.
Don, thanks for that bit, pretty much what we were thinking. regards bill.
By Pete's Panel - 16 Years Ago
Hi Ted, do you think the performance of the Cain manifold will improve with the alloy heads???
a couple of photos for those not familiar with this inlet.
By unibodyboy - 16 Years Ago
Ted,
Noticed that in the 3x2 testing you did a while back, the Edelbrock 573 (1. 336.0 Tq / 279.3 HP - Edelbrock ‘573’) came up with similar peak numbers as the 4bbl (G heads are 286.1 HP @ 5300 rpms and 336.4 lbft torque @ 3400 rpms) on this series of tests. Would your opinion be that the peak numbers from both of those tests are due to the restricting nature of the iron heads in both cases? I know you are quite busy, but any chance you cold run the 573 on the aluminum heads just to give us an idea what that combination is capable of?
You guys have done such an awesome job, I hope that the financial returns to you both will make this endeavor very worthwhile.
By randyh - 16 Years Ago
John, The combustion chamber is small compared to the supercharger heads, what changes to head or pistons would be required to use these with a VR57 blower and what do you think performance would be?
By Fordy Guy - 16 Years Ago
  And Don, I received my latest issue Friday the 14th.
By John Mummert - 16 Years Ago
A minimum piston to head clearance of .035-.040" is maintaned to prevent the piston from contacting the head. Less clearance usually will mean less chance of detonation regardless of the cylinderhead material.
Piston skirt length and piston to cylinder clearance should be taken into account if you are looking to reduce this clearance below commonly accepted minimum of .035". A short piston skirt will allow the piston to rock more as will additional piston to cylinder clearance.
With regard to pricing ect. We plan to place an order for head castings around the 1st of June. The more deposits we have, the more castings we will order. Deposits of $1,000.00 received before we order castings will result in a final total price of $2049.00 (1000 + 1049) for 2 assembled heads. Orders received after we order castings will be at a higher price.
Anticipated delivery of the finished heads will be late July 2010.
Air, like anything else, takes the path of least resistance. I found when testing a 3-2 intake on a flow bench that over 80% of the flow came from the carb closest to the port being tested. About 15% came from the center carb and the carb farthest away could be opened and closed with almost no noticeable gain or loss.
I don't know what size carbs Ted used on the 3-2 testing but when HRM did extensive testing of a 312 back in 1956 they eventually had to bore the carbs to make maximum power. As I recall they were using .94"s and could only make 271 uncorrected HP. When they bored the carbs they made slightly over 300.
They gave a formula for optimum venturi size related to engine size. I would have to find the formula, can't remember. It was somewhere in the 50 - 55 cubic inch of displacement per square inch of venturi range.
Although I've never tested a 3-2 set up we have found some definite trends with Y-Block engines. We found that with 9.5:1 compression and a streetable cam a Y-Block with ported factory heads could make 1.07-1.10 ft. lbs per cubic inch. This covered a number of builds from 314 cu in to 337 cu in and 224 @ .050" cams up to 240 @ .050" cams. Intakes ranged from modified 1957 ECZ-B intakes to Blue Thunder to Edelbrock 257 2-4 intake. The 314 made 1.13 ft lbs per cu in but had 10.0:1 CR.
Ted's stock head dyno mule comes in just a shade under that and experience indicates that ported heads will only add 10-15 ft lbs to that engine.
From the testing I have seen stock ECZ-G heads are limited to 285HP +-5. A good port job can take this up to 325-360 depending on cam, compression and displacement.
Porting Y-Block heads can make a substantial difference in HP but will have little effect on torque. All testing was done with either ECZ-G or -113 heads.
To make over 365hp with ported factory heads the testing I've done indicates that the CR must at least 10.5:1 and the cam needs to approach 250 degrees @ .050". Displacement will need to be 330+ cu in.
A lot depends on the size of the engine. A .060" over 292 will have 9.75:1 compression if zero decked. If a lower CR is desired a dished piston will easily lower compression. The VS57 doesn't work that well with very low compression so best to keep it in the 9.25-9.75 range.
By jepito - 16 Years Ago
By Noob - 16 Years Ago
Is it wrong thinking to prefer the smooth and predictable curve of the new head with 4-hole spacer (the red curve) and let the tranny and drive line ratios do the work in the sweat spots?
That double-hump in the blue curve looks like it could be annoying as far as the seat of the pants signalling goes.
Cheers... Brian
By MarkMontereyBay - 16 Years Ago
I am impressed. Getting ready to pull the 312 from my 57 Bird in a few weeks or so. I will be using a 573 and 94's with Sanderson headers, MSD, etc. Unfortunately, I didn't get the Yblock Magazine this month. I thought my subscription was paid up but I have been living away from the house as it is being remodeled and the mail is a bit chaotic right now. So please, someone post what the expected cost of these new jewels will be.
Thanks,
Mark
I called John and gave him a deposit today. Still haven't seen the latest Yblock Mag in my mailbox. With delivery of the heads by late July, it leaves me some time to clear up some other stuff. I am finishing up a home remodel in the next week or so. Then clear out the garage and install/tune the 79 Tbird disk brakes on my 65 Galaxie (daily driver). Once that is done the 312 comes out of my 57 Bird to repair a trans leak (torque converter). The motor is a solid runner with good compression which was rebuilt in Salinas some years ago. I will check the bottom end while it is out and check the cylinders. If all is good it goes back together with the Mummert heads, Sanderson's and 3 94's on a Edlebrock 573. If the short block needs freshening it will be done but I doubt it needs it. Not sure about a cam change. Leaning toward leaving well enough alone as it runs so well. But...there is a guy in my area with a sharp looking red 57 Corvette 283 that cruises by my place once in awhile. I have a history of good old Fords in my garage and driveway so the scrub guys, who get bored bumping bellies with each other, have been known to slip by here and make themselves evident. BTW, the 57 Vette runs awful, not a car guy by my estimation. Typically, here it is about money and profile, not about tool boxes and know how.
Mark
By Grizzly - 16 Years Ago
Impressive!! A 20% increase from the new heads. I, like most, would like to see a comparison chart for the testing done.
It's interesting that there is an improvement, even at lower RPM, with a spacer. I would have thought that the standard heads would be giving close to full volumetric efficiency there. The ram effect obviously doing it's thing with a longer inlet. This is what John was talking about getting an improvement over wider range of RPM.
With more testing to come we will obviously see and get more information. I would like to see the same test done with heads that have had the ports finished to remove the rough casting surface.
Thanks for the detailed graph Ted. You guys have done some great work.
I don't get Y block magazine (yes I should) I was also interested in purchase details. Also how long before they're ready for release.
Guy's,
Ted is approaching testing these parts the right way. When evaluating parts you must have a base where each item is tried. This is the only way to check what characteristics each part will give. Some minor tuning with jetting and ignition timing is acceptable.
As a guideline you can use the percentage gained by the heads and use that percentage 56Hp(increase)/291hp(base)  19.243% to get your peak against what was tested before with the 3x2 shootout. This peak will change throughout the rev range and should be considered point to point.
In evaluation part for an engine build you start with an understanding, a desirable outcome and try different parts in different configurations to obtain a desired result. This is something that only top engine builder can afford for one engine not for the entire range of parts available. Not even for Y block.
We are getting a lot of information from some guys who have taken a financial risk to produce a part for something they love.
Sweet!
Did you calculate average numbers?
Is it normal for aluminum heads to grow like that and affect the valve lash so significantly?
Do you think the aluminum heads might produce more torque than a ported iron head below 2800rpm?
And a not so important question but a curious one, does the leaner mixture actually result in better mileage?
I'm thinking this is going to be a particularly exciting year at Columbus!
I'm interested in seeing how the 3x2 does, too. And also to see how they stack up against ported iron heads.
In the 3x2 testing post, Ted said that an engine he dyno'd in the past made 340hp with a 573 and that it was rich and most likely would have made more. That's why I want to see how the 573 compares. If it's near the 4v's, it'll be 3x2's for me.
By Ted - 16 Years Ago
The wait is over as the new Mummert aluminum heads have now been run on an engine with the following results.  56 horsepower increase over the stock heads!!!!!!  In their first day, a total of 24 pulls were made with the aluminum heads to test a variety of timing, carburetion, carb spacer, jetting, and exhaust changes.  The aluminum heads themselves were tested as delivered and used in the ‘out of the box’ configuration with no porting being performed.
The engine used for the test is a +060 over 312 with the cast flattop pistons 0.025” in the hole and stock G heads that had only a good valve job with hardened seats installed and a 0.025” mill to clean up the deck side of the heads.  No port work.  The compression ratio calculates to be 9.2:1.  The engine is running the factory 1.54:1 rockers, Mummert single four intake manifold with a two inch four hole spacer, and a 750 cfm vacuum secondary carb.  The camshaft is a Crower Monarch grind ground on 110° lobe centers, 280° advertised, 238° @ 0.050”, and 0.430” lift at the valve after the lash is set.  Prior to the head test, a 465 Holley, a modified 600 Holley, and a 750 Holley were all tested and the 750 simply shined above the rest.  The 465 just gives up earlier and the 600 fell in behind the 750.  These same carbs were used with the aluminum heads with the performance order being the same but much more pronounced.
To keep the tests reliable and truly comparitive, both the iron and aluminum heads were ran back to back and on the same day.  The engine was ran first in the morning with the iron heads to get some baseline numbers.  The dyno numbers for the G heads are 286.1 HP @ 5300 rpms and 336.4 lbft torque @ 3400 rpms.  Although there was a 290HP number on one of the pulls, it was disregarded due to the water temperature being on the cool side.  These are still respectable numbers for stock unported G heads.
It took just a bit over two hours to swap out the iron heads to the aluminum versions.  The engine was then started, heated up, stopped, and allowed to heat soak.  At this point the valve lash was rechecked.  As an FYI, the heads grow about 0.004” from ambient to hot so setting the valve lash at 0.015” initially nets 0.019” hot.  After a series of dyno pulls to determine what the engine preferred for new ignition timing and fuel mixture attributes, the numbers for the aluminum heads are as follows:  340.6 HP @ 6100 rpms and 357.5 lbft torque @ 4400 rpms.
The new heads do like leaner fuel mixtures and considerably less total timing.  They are definitely more efficient.  Whereas the iron heads liked 38-40° total timing, the aluminum heads are happiest with 32-33° total on this particular combination.  Intial testing shows an Autolite 3924 spark plug being a good middle of the road spark plug to start out with.  Spark plug gap for the tests was at 0.035”.
With ‘out of the box’ aluminum heads and no port work, 1957 supercharged performance is now available without having to use the supercharger.  There is still some more dyno testing yet to be performed after which point the heads will be pulled off of the engine and disassembled.
charliemccraney (5/14/2010)
Here are some average numbers.  Keep in mind that the iron head numbers are biased larger because they are averaged to 5500 rpms while the aluminum heads are averaged to 6200 rpms.  Had the iron heads been taken to 6200 rpms, the iron head average numbers would have been considerably lower.
Iron heads w/4 hole carb spacer:     238.3 HP, 315.8 lbft TQ  (averages)
Alum heads w/4 hole carb spacer:   270.8 HP, 331.9 lbft TQ  (averages)
Alum heads w/tapered carb spacer: 271.7 HP, 329.5 lbft TQ  (averages)
The growth of the heads is perfectly normal with aluminum.  I see as much as 0.006” growth on SBF heads.  The combination of aluminum heads and an aluminum block on my FE sees a total of 0.025" growth.
At 2500 rpms, the iron heads had 298 lbft TQ while the aluminum heads with the same 4 hole spacer had 315.3 lbft TQ.  With a tapered carb spacer being substituted for the four hole spacer in conjunction with the aluminum heads, the iron heads were only slightly better for torque below 2800 rpms.
As far as fuel efficiency, John can answer this one better than myself but because the Brake Specific fuel numbers are lower and the engine does require less jetting to get more out of it, I’ll take a stab in the dark and say YES, the heads will get better fuel economy with the appropriate tuneup.
Daniel Jessup (5/14/2010)
Ted, that is great baseline info for these heads! Can we automatically assume that these heads are gonig to be used on your EMC motor?
This particular pair of heads will go on a customers engine once final checkout is performed.  A different and fully prepped set of heads will go on the EMC engine.
jepito (5/14/2010)
Chamber sizes are 65.7cc for the iron heads and 60.0cc for the aluminum.
DANIEL TINDER (5/14/2010)
For a ½ point compression ratio increase on iron heads, figure a 2% increase in peak horsepower numbers.  In this case where the heads were switched from iron to aluminum and the aluminum ended up being 0.6:1 higher for the compression ratio (cr), it’s a wash or net zero increase.  Simply put, aluminum just isn’t as efficient as cast iron in converting the combustion heat into power.  To offset the inefficiencies of aluminum in the combustion process, a given increase in cr is required to keep the power levels the same with everything else being equal.  Had the aluminum heads been designed with the same size combustion chambers as stock, then a portion of the power that was a result of improvement in head flow and combustion chamber design would simply have been lost due to  having to make up for the lost power due to the thermodynamic properties of the aluminum.  That’s the simple explanation.
Y block Billy (5/14/2010)
I guess I should have clarified growth as ‘net growth’.  The net growth is 0.004” regardless of which parts are growing.  The aluminum heads could be growing 0.006” while the pushrods are growing 0.001” and the valves themselves are also growing 0.001" which still makes net growth 0.004” when  performing a cold versus hot valve lash adjustment.  At this point, all that needs to be known is net growth so that when the cold lash is adjusted, hot lash is in the ball park.  The difference in lash with aluminum heads from cold to hot is a 0.004” increase.
Here are a pair of graphs.  The difference in the two carburetor spacer designs is why you test.  A street driver would like the four hole spacer while a racing or ‘spirited driving’ application will prefer the tapered design spacer.
marvh (5/16/2010)
marv
This was a core engine that was already 0.060" overbored and simply rebuilt to use as a dyno mule.  The block decks were straight so they were not cut upon on this latest rebuild which kept the pistons at 0.025” in the hole.  The deck side of the heads were cut 0.025” though to give a surface that was smooth enough to seal with.  The iron 'G' heads used for testing had considerable rust on the sealing surface before preparing them for use.  This particular short block was originally put together in the Seventies with the current pistons and it would appear that only a cleanup mill was performed on the block decks at that time.
The intake manifold fit was fine on the aluminum heads and no additional work was required as such.  The iron ECZ-G heads had been milled ~0.025” and the same intake manifold fit fine on those also but I typically don’t start to see a problem with manifold fit until at least 0.045”-0.050” is milled from the heads and/or decks.  I didn’t ask John if the aluminum heads were machined with composition gaskets in mind or if machined to the original ‘steel shim’ head gasket specs.  Regardless of how they are machined, everything fits up just fine.  On an unmachined and stock Y block and using the stock cylinder heads and composition gaskets, the heads will sit ~0.020” higher than stock if no milling of the heads or decks takes place.
Noob (5/18/2010)
There are a multitude of combinations which will alter the torque band.  Carburetor and/or carb spacer changes are just one way to alter these curves but there are many others.  Advancing or retarding the camshaft is another just as changing the camshaft itself can give completely different results.  And don’t forget the exhaust system.  Too many times altering one component means changing up the rest of the combination to make it optimal again.  The combinations are endless and simply comes down to how the vehicle is being driven as to what is the most desired torque band.
unibodyboy (5/18/2010)
Ted,
The similarity in rpm torque bands between the single four and the three deuce intake testing was indeed related to the fact that the same heads were used for both but the camshaft also plays into this as well.  Had the camshaft been a different grind but remained the same for both the 3X2 and single four tests, the peaks would have changed from the camshaft that had previously been used.  But testing with some specially tailored four barrel carbs as well as some different exhausts on the iron heads has had some dramatic effects on low end torque production so it’s still the total combination that must be considered.
It was interesting to note that the peak horsepower of the dyno mule engine went from 5300 rpms with the iron heads to 6100 rpms with the aluminum heads.  Same camshaft, same intake manifold, same carb spacer, same rocker ratios, same exhausts, and same carburetor.  By switching only the heads, the differences in torque production as well as the usable rpm ranges could be definitively evaluated.
Time constraints has put any additional 3X2 testing on the back burner for the time being.
Pete's Panel (6/3/2010)
Pete.  I doubt that I’d see any improvement in the numbers originally posted by the Cain manifold if used on the aluminum heads.  Torque band was flat and low on the ported heads that the Cain manifold was tried on and that was simply due to the runnerless design of the manifold.  But I do have plans to run that manifold again in the future on another set of ported iron heads while experimenting with some plenum dividers and different carb spacers.  All this is being done just to see if the manifold can even come close to matching the performance of some other intakes I have here.  Any information learned from this can go into the development of a true single plane intake for the Y.
