1956 victoria "window flipper"
http://forums.y-blocksforever.com/Topic4340.aspx
By Gerry - 18 Years Ago
The "L" shaped tab that the wing window hits on closing the door for the window flipper. I need one. If you have a flipper that is not good as long as I can remove that tab and put it on mine or if you have a good drivers side flipper I can work with. Thanks Gerry
