Ecg-Z heads for sale
http://forums.y-blocksforever.com/Topic41549.aspx
By SOCAL PETE - 15 Years Ago
I have a set that was just worked by John
I decided to go with the aluminum instead.
Theses heads are bare.  NO Valves.
Valve guides, with positive seals installed
hardened seats on intake and exhaust.
Spring seats cut for high pressure springs.
Asking $750 OBO    760-315-0542.  Will ship.
By Ol'ford nut - 15 Years Ago
ECG-Z? or ECZ-G
Minor typo...it happens when your doing ten million things at work and posting a ad.
Here are the specifics.
Heads ECZ-G Heads.
Bronze guide liners
Hard seats Intake and exhaust
Cut for positive seals.
Surfaced -.025 Combustion chambers would be 66 to 67 cc as per JM
Guides shortened for high lift springs.
By NoShortcuts - 15 Years Ago
Pete,
Please answer a couple of questions regarding the heads you have.
1) there are three species of 'G' heads. The casting letters ECZ-G are either small or large. Which do you have? Note: The intake and exhaust porting is different on the two... different cores were used in making the castings.
Also, IF the heads have the large casting letters ECZ-G they may be early or late heads. The early heads are not posted while the late heads are. Do you know which you have?
2) has porting work been done on these? By John? If done by John, are they 'Street Port' or 'Race Port'?
3) were hardened seats installed for original size valves or for the oversize diameter valves that John sells?
Thanks.
Syracuse, NY
Also, IF the heads have the large casting letters ECZ-G they may be early or late heads. The early heads are not posted while the late heads are. Do you know which you have? These are the NON POSTED Large letter heads
2) has porting work been done on these? By John? If done by John, are they 'Street Port' or 'Race Port'? I will check with John Mummert to see which and what porting has been done.
3) were hardened seats installed for original size valves or for the oversize diameter valves that John sells? original size valves
Thanks.
Syracuse, NY
