By Ted - 15 Years Ago
Dyno testing is now complete on the 3X2 intake manifolds. The Edelbrock 573 was at the top of the heap with the Offenhauser being at the bottom. There was a 29HP difference between the best and the worst which is a bunch. The dyno test range for each test was 2500-5500 rpms. Besides looking at both the peak and average horspower and torque values, the engine performance with each intake was also ‘scored’ to get a better feel for overall performance using a single value. The score is calculated by adding both the average HP and torque together and dividing that into the cubic inch of the engine and then multiplying that value by 1000. Testing concluded with the first intake being rerun at the tail end as a validation that the engine was holding steady and because there was still some time left at the end of the day, the new Mummert intake was installed with a 600+ vacuum secondary Holley on top of a 2” four hole spacer and also ran. Here’s how the various 3X2 manifolds ranked in overall performance from the top to the bottom. 1. 1703.7 pts - Edelbrock ‘573’ 2. 1674.7 pts - Edmunds ‘DM-425’ large port 3. 1672.4 pts - Edelbrock ‘553’ 4. 1667.7 pts - Edmunds ‘DM-424D’ small port 5. 1661.2 pts - Weiand ‘FM436’ large port 6. 1646.9 pts - Edmunds ‘FORD 424’ small port 7. 1561.2 pts - Offenhauser w/no identifying numbers The test engine is a +060 over 312 with 9.2:1cr, dead stock ‘G’ heads, and Harland Sharp 1.6:1 rockers. The same Stromberg carbs were used on all the manifolds without any jetting changes once manifold testing commenced. The camshaft is a Crower Monarch with 238° @ 0.050”, ground on 110° lobe centers, installed 2° advanced, and 0.434” lift at the valve after valve lash. All testing was performed with four tube headers running through Magnaflow mufflers. This series of 3X2 intake manifold testing is also part of the durability testing being performed on the prototype Harland Sharp rockers which so far appears to be holding up fine. For those of you that live and breathe horsepower and torque numbers, here are the peak values for the 3X2 intake manifolds but are still being listed in their order of scoring. 1. 336.0 Tq / 279.3 HP - Edelbrock ‘573’ 2. 336.1 Tq / 266.5 HP - Edmunds ‘DM-425’ large port 3. 334.1 Tq / 270.1 HP - Edelbrock ‘553’ 4. 338.6 Tq / 260.1 HP - Edmunds ‘DM-424D’ small port 5. 332.1 Tq / 266.2 HP - Weiand ‘FM436’ large port 6. 330.4 Tq / 261.9 HP - Edmunds ‘FORD 424’ small port 7. 311.5 Tq / 250.8 HP - Offenhauser w/no identifying numbers And here’s the order in which the intakes were run on the engine. 1. Edelbrock ‘573’ 2. Offenhauser w/no identifying numbers 3. Edelbrock ‘553’ 4. Weiand ‘FM436’ large port 5. Edmunds ‘FORD 424’ small port 6. Edmunds ‘DM-424D’ small port 7. Edmunds ‘DM-425’ large port 8. Edelbrock ‘573’ (reinstalled to validate earlier run) 9. Mummert single four intake with 600 Holley (291.9HP / 346.0Tq) Intake manifold changes were down to 35 minutes each at the end.
And here’s a shot of all seven 3X2 intakes that were tested.
Top Row (left to right) Edelbrock ‘553’, Edmund ‘DM-425’, Edmund ‘DM-424D’, Edelbrock ‘573’ Bottom Row (left to right) Weiand ‘FM436’, Edmund ‘FORD 424’, Offenhauser
By YellowWing - 15 Years Ago
Ted, Thanks for doing this! Very interesting the difference in HP figures for the different manifolds. Also interesting how easily the Mummert beat them all. Thanks again, Mike
Ted,
Wow....that is an impressive test. Thanks very much for all the work and clearly posted data. I was hoping the 573 would place a little better against Mummert's but reality wins out. For those of us still addicted to the 3x2 configuration, I wonder if some modifications are possible for the 573 to improve it. I may just keep the Mummert manifold on the shelf with an extra set of gaskets for easy swapping.
Thanks again.
Mark Hebard
I'm surprised to see how close the Edelbrocks are to one another. It looks like the first six will work nicely on a driver. And the Offenhauser is not really as bad as it's made out to be. In most cases, each manifold will support higher than stock performance. In my mind, that means they work as advertised.
By lowrider - 15 Years Ago
Thanks Ted. Although I'm running the 553 it sure outdid the Offy I had on it.
By BIGREDTODD - 15 Years Ago
Excellent information Ted! Thanks for all the work and the clear presentation of the numbers...
By mctim64 - 15 Years Ago
This is a good reason to be here, among many others, you just don't find information like this anywhere else. Thanks Ted for all your work, it's a great help to all of us.
By joey - 15 Years Ago
Awesome research work Ted!
By bird55 - 15 Years Ago
Fine work, Ted!
Thanks again for all the hard work you do for the y-blockers.
What a great benefit it is to be here.
By Cactus - 15 Years Ago
Ted, thanks for all your research and tests. I almost can't believe I have carried that Offy manifold around for almost 40 years, Oh well. Very interesting information. I will continue to use it as a nice garage wall decoration. I have an Edelbrock 573 that I plan to use, so I am in good shape.
By BFOOTER03 - 15 Years Ago
Thanks for the testing Ted. Appreciate all the work.
By gritsngumbo - 15 Years Ago
Thanks for spending the time to do the test for the rest of us. It is appreciated and justifies my purchase of the "573" (a 63 Uni Long Bed came with it :-) )
By aussiebill - 15 Years Ago
YellowWing (3/4/2010) Ted, Thanks for doing this! Very interesting the difference in HP figures for the different manifolds. Also interesting how easily the Mummert beat them all. Thanks again, MikeWasnt the mummert intake a 4bbl?.
By Daniel Jessup - 15 Years Ago
Ted - in a word, WOW! What great stuff! Sounds like a nice article for Y block magazine to me (and for any other car magazine). Wonder how the stock B manifold would stack up against Mummert's, just to show the overall improvement between the two. Maybe that information is already on the forum somewhere?Thanks for all your hard work, the Y block nation commends your efforts!!!!
By Nick Brann - 15 Years Ago
Ted, A big "Thank You" to you and your crew for the comprehensive test. I'm sure it was a labor of love, but it was still a lot of time and effort. Will help us to build even stronger Y-blocks. Now, of course, I wish I hadn't sold my Edelbrock 573 and Stromberg 48's that I ran in the 60's. Keep up the good work! Nick Brann, K.C., MO - '57 312
By paul2748 - 15 Years Ago
Which Mummert 4bbl intake was used? The new one or the Blue Thunder?
By Eddie Paskey - 15 Years Ago
Hey Ted; Sure appreciate you taking the time to help us all-- with the test. Thanks for the education and the caring. What a wonderful site!!! God Bless you All
By 57 ranchwagon - 15 Years Ago
Thanks Ted super cool don't see that info very often anymore.
By ecode ragtop - 15 Years Ago
AGAIN, TED THANK YOU FOR ALL THE WORK YOU DO TO MAKE THIS ONE OF THE BEST SITES ON THE WEB. TOM
By Philo - 15 Years Ago
I'll chime in...Fantastic job Ted! You are truly an asset to Y-Block lovers everywhere. Which model Strombergs were used? Stock jets? The compression ratio (9.2) on that dyno engine seems pretty low for the cam being used. It would seem that 10.0 or more might be optimal. What octane fuel was used? Now I'm glad I traded my Offy 3-2 manifold for a pair of posted G heads! Thanks!
Philo (3/5/2010)
Which model Strombergs were used? Stock jets? The compression ratio (9.2) on that dyno engine seems pretty low for the cam being used. It would seem that 10.0 or more might be optimal. What octane fuel was used? The Stromberg carbs being used simply say ‘97’ on their side. They are big numbered on the end carbs and have a small number imprint on the center carb if that helps with the model identification. The Strombergs are all jetted with #48’s for the test. Originally started out with 45’s in the ends and 48’s in the center but the engine was running just a tad on the lean side and rejetting the end carbs fixed that. A big Thank You goes to AussieBill again for the extra jets to get those carbs ‘on the money’.91 octane pump gas is being used for all Y-Block testing at this point with the stock heads in place. Total ignition timing is 38° BTDC using a MSD distributor. Engine has 13” vacuum at 850 rpms for what its worth. Performing a cranking compression check is on the list before changing the heads out for some heavily milled heads in the near future. Engine sounds strong at idle even with 9.2:1cr. 118 pulls on the engine thus far and just now starting to pick up traces of some oil leakage from around the rear main seal area.
paul2748 (3/4/2010) Which Mummert 4bbl intake was used? The new one or the Blue Thunder?The aluminum 4V intake being referred to is the new Mummert offering. I have tested the Mummert intake against the Blue Thunder piece on two different engine combinations and the Mummert intake came out on top in both instances. Because the exhaust system being used on the 312 dyno mule has been found to be too restrictive during the single 4V intake testing, some of the tests will be repeated in the near future using the same exhaust system that was used for the 3X2 testing. The Mummert and Blue Thunder intakes were also tested on the EMC engine in back to back testing and the Mummert intake really shined on that combination peaking out at 464 HP on pump gas. That engine still idled nicely at 950 rpms with a 254°/258° @ 0.050" camshaft and the Mummert intake.
By pegleg - 15 Years Ago
Awesome test Ted. That took an hour or two! Where would the "B" intake with the original 4 BBl fit into this? I suspect all the aftermarket three-two intakes were developed before the '57's came out. Meaning that the only factory intakes available would have been the 2bbl's, or an A intake with a teapot. I'm not counting the dual quad intakes because those were really rare, I don't ever remember seeing one on the street.
By bloodyknucklehill - 15 Years Ago
pegleg.. I think the edelbrock 573 came out in '57 and the 553 in '55, at least that's what i read somewhere.. the rest of them i don't know.. that could be the reason it outperforms the rest
By PF Arcand - 15 Years Ago
Good job Ted. The only other manifold I would have liked to have seen tested would have been a Fenton. Anyway, the tests confirm the negatives about the Offenhauser that were in an article by Doug Thrasher in YBM #55, Mar-April 2003. At -29 H.P. & -25 Ft. LB. behind the Edelbrock 573, the Offy intake would make a good garage ornament...
By Doug T - 15 Years Ago
Hi Ted, Great article and nice to have one's judgement about the Offie's confirmed. Of course the old Popular Hot Rod article result compared to the '56 HRM/Edelbrock tests made it a pretty easy guess. BTW The HRM/Edelbrock test finally took the '56 Ford carbs they used and machined the venturi's out from 1.06" to 1.187" dia. The 97's are 0.97" venturi dia. which is a severe reduction. It would be interesting to know what the venturi area of your test 4bbl is. But it seems like the 753 is a pretty good manifold.
Doug T (3/5/2010) BTW The HRM/Edelbrock test finally took the '56 Ford carbs they used and machined the venturi's out from 1.06" to 1.187" dia. The 97's are 0.97" venturi dia. which is a severe reduction. It would be interesting to know what the venturi area of your test 4bbl is. But it seems like the 753 is a pretty good manifold.1.250” on the primaries and 1.312” on the secondaries are the venturi diameters on the L1850 Holley being used on the Mummert 4V intake at the tail end of the 3X2 test session. Total agreement on the ‘573’ being a good manifold. It had already previously been dynoed on a souped up Y that was making 340 hp with #50 jets all the way around and was a good indicator that the Edelbrock ‘573’ with Strombergs has some great potential. It was on the rich side on that particular engine and with the leaner jets that are in it now, it would have undoubtedly made some even bigger numbers.
Great Job Ted! Couple questions while you still have the intakes on hand, It is funny to note that the small port Edmunds DM-424D had the best torque numbers. What is the difference in the 2 Edmunds 424's? The one I sent you are calling the FORD 424. I did notice before I shipped it, it had been repaired in one runner which could have added a small restriction to that runner. I also noticed it had plenty of meat for hogging out, if you want to do an experiment by porting it out to a large port etc while you have the setup, have at it, I don't see myself needing it in the near future. You could then compare a ported 3x2 to a mummerts etc. 2nd, Do you have any low end torque numbers you could post? Most people don't get to hold their cars at the peak horse rpms very often, but they like the off the line tire fryer capabilities at the low end torque scale.
Y block Billy (3/6/2010) .....Do you have any low end torque numbers you could post? Most people don't get to hold their cars at the peak horse rpms very often, but they like the off the line tire fryer capabilities at the low end torque scale.Billy. Here are the lowend torque numbers and are rounded off for easier viewing. The new scoring order is in the bottom row if simply basing the performance of each intake on its lowend torque values. The Edmunds DM-424D in this format would be the best from a daily driver point of view but all the Edmunds 3X2 intakes still look good. No matter how you look at the Offenhauser intake though, it just comes up short. rpm | Edel 573 | Edmunds DM-425 | Edel 553 | Edmunds DM-424D | Weiand | Edmunds Ford 424 | Offy | 2500 | 292 | 303 | 296 | 309 | 293 | 294 | 277 | 2600 | 305 | 314 | 308 | 320 | 306 | 306 | 287 | 2700 | 313 | 323 | 316 | 328 | 316 | 314 | 294 | 2800 | 321 | 329 | 322 | 334 | 322 | 319 | 300 | 2900 | 325 | 332 | 327 | 336 | 327 | 323 | 305 | 3000 | 328 | 333 | 330 | 337 | 330 | 326 | 308 | 3100 | 330 | 334 | 332 | 338 | 331 | 327 | 310 | 3200 | 333 | 335 | 333 | 338 | 332 | 328 | 311 | 3300 | 334 | 336 | 334 | 339 | 332 | 330 | 311 | 3400 | 335 | 336 | 334 | 338 | 332 | 330 | 311 | 3500 | 336 | 336 | 333 | 337 | 332 | 330 | 312 | Avg | 322.9 | 328.3 | 324.1 | 332.2 | 323.0 | 320.6 | 302.4 | Order tested | 1&8 | 7 | 3 | 6 | 4 | 5 | 2 | Overall scoring order | 1 | 2 | 3 | 4 | 5 | 6 | 7 | Revised scoring order | 5 | 2 | 3 | 1 | 4 | 6 | 7 |
The two Edmunds 424 intakes are different in appearance at the backs of the manifolds and obviously came from different molds. One has 'Ford 424' on it and the other 'DM-424'. The DM-425 and DM-424 manifolds each have ‘425’ and ‘424’ cast also on their insides in a couple of places but the ‘Ford 424’ manifold does not have those same identifiers on the inside of the manifold. Both the 424 intakes are small port versions though whereas the 425 is a large port intake. Looking at your Edmunds 3X2 intake, I can see where it has been repaired on the inside but the repair doesn’t look to be a problem.
By RB - 15 Years Ago
Ted did you record vacuum during your 3x2 tests? I was wondering if the 97's were able to supply enough air
Royce. All I have for manifold vacuum readings for the 3X2 testing is 13”Hg @ 850 rpms. I didn’t have the computer vacuum hooked up on any of the manifolds during the testing so full throttle vacuum data is not available ……yet. The Edelbrock 573 will likely be installed on the engine again at which point I’ll be sure to record WOT vacuum readings. I suspect the vacuum is still less than 1”Hg at 5500 rpms but will not know for sure until I actually confirm. I’ll add that a problem with the Strombergs was noted before the testing even started in that the carbs would not open up fully even with the carbs off the manifold and in hand. It took some modifications to the carbs themselves to correct this problem but they worked much better than expected when it was all said and done.
This continues to be a very interesting discussion. The flow area in the venturi's is a useful number to know but it does not translate directly to CFM for practical purposes because the design of the boosters is different and can effect the actual flow. However calculating the flow area is easy once you have the dia of the venturi and for Ted's tests here are the numbers: 3 Stromberg 97's 4.43 Sq inches Venturi Dia 0.97" The Holley 4 BBL 5.15 Sq inches 3 '56 Ford 2bbls 5.29 Sq inches Venturi Dia 1.06" 3 Modified '56's 6.64 Sq inches Venturi Dia 1.87" This is what the Edelbrock test used at the end. Based on these numbers there seems to be plenty more in the 573 manifold and probably the others too. The vacuum under full load will be interesting. It would also be interesting to see the results of a ported '57 B manifold. Ted do you want one to try?
Doug, i would be curious what the modifications of the 94 carbs were? thanks, regards bill.
Doug T (3/8/2010) ....It would also be interesting to see the results of a ported '57 B manifold. Ted do you want one to try?Doug. I actually have several B manifolds here ported in different configurations as well as a B manifold that’s been extrude honed. And I’ll bet you can guess who loaned me the extrude honed manifold. But if you would like your particular posted intake compared to the others sitting here, I’ll be more than happy to run it along with the others when the time comes. Spacer recommendation on your particular manifold is also welcome. I can return the intake to you at Columbus. I’m at least 2½ months off before that particular test takes place so no there’s no real hurry right now. The current plans are to test the various modified B intakes along with the Blue Thunder and new Mummert intakes on ported heads as I believe it’s a moot point to do that testing on the stock heads that are currently being used.
aussiebill (3/8/2010) Doug, i would be curious what the modifications of the 94 carbs were? thanks, regards bill.Bill. The modifications were all external and had to do with the original carb linkages and throttle stops on the accelerator pump linkage side of the carbs. The carbs were essentially binding up in that area preventing the throttle blades from opening up all the way. Some careful bending and a file fixed those problems.
Ted (3/9/2010)
aussiebill (3/8/2010) Doug, i would be curious what the modifications of the 94 carbs were? thanks, regards bill.Bill. The modifications were all external and had to do with the original carb linkages and throttle stops on the accelerator pump linkage side of the carbs. The carbs were essentially binding up in that area preventing the throttle blades from opening up all the way. Some careful bending and a file fixed those problems. Ted, thanks for the info, i,m sure we can all say a big Thanks for the Unbelievable amount of R & D time you put in on our engines, its very enlightening the potential the engine does has, i believe all this testing and trying different intakes, combinations has never been done before and hence the y block was seen by the general populace as a lesser choice of engines, but the true believers can sit back and see it emerge through the clouds of doubt into the forefront of popularity! Thank you again. best regards bill.
RB (3/7/2010) Ted did you record vacuum during your 3x2 tests? I was wondering if the 97's were able to supply enough airRoyce. I had the opportunity to retest the Edelbrock #573 3X2 setup with the Stromberg 97’s on the aluminum headed engine but this time while taking vacuum readings throughout the course of the dyno pulls. The Stromberg carburetors are indeed restricted in the upper rpms as the manifold vacuum backed up to 2.0”Hg in the upper rpm ranges. In this instance, this 3X2 intake can definitely benefit from either modified or larger carburetors. The lowend torque values with this particular 3X2 setup are still extremely good though.
Ted, during the testing with the Strombergs were you using vacuum advance. Stromberg throttle bodies with vacuum ports are very rare and if you used vacuum advance I was wondering if you have the rare stock ported throttle body, modified the center throttle body or hooked it up some other way.
Sorry if it was mentioned in the thread and I missed it.
By LON - 14 Years Ago
Ted , Ditto to what "Cusso Bill " said .You are truely a living legend on Y-Blocks . I am sure you & JM ,along with a few others will go down in history as true believers .We can never repay you for your time & effort that you put into these magic motors .I am certain you will be highly spoken of years to come .Once again ,a BIG thank you for your time .Words can not express how much we,on this site , appreciate it .You are truely worth more money . Regards Lon
By Fordy Guy - 14 Years Ago
Ted, just being curious, but how many runs do you think you have made on that test mule engine without having to do anything major to it? There's got to be a dependablity factor in there beings it's a Y-Block!
By fairlane bob - 14 Years Ago
WHY????
I am wondering why you would think the Y-block would be any less dependable than any other engine?????
By Ted - 14 Years Ago
Fordy Guy (11/26/2011) Ted, just being curious, but how many runs do you think you have made on that test mule engine without having to do anything major to it? There's got to be a dependablity factor in there beings it's a Y-Block!At pull #365, the short block was pulled down so a sleeve could be installed in cylinder #8 to take care of a lateral crack that was forming. The engine was reassembled using the same rings and bearings as there was absolutely no wear on the bearings being evident. Other than that, the engine has been rock solid. This is the same basic short block combination that was put together in the Seventies and part of what I did on this end to prepare it for dyno testing was a rebalance with new rings and bearings. I'll add that I installed bronze cam bearings to fix a twisted cam tunnel that was present when preparing this engine as a dyno mule. The engine now has over 400 dyno pulls on it and still more testing with both heads and exhaust are in the works.
Bill & Lon. Thanks for the accolades.
The Master Cylinder (11/25/2011) Ted, during the testing with the Strombergs were you using vacuum advance. Stromberg throttle bodies with vacuum ports are very rare and if you used vacuum advance I was wondering if you have the rare stock ported throttle body, modified the center throttle body or hooked it up some other way. Vacuum advance was not used on the 3X2 test. The distributor being used is a MSD p/n8383 and only the mechanical advance capability was being used in those tests.
Thanks, Ted. I looked up the instructions on the MSD Distributor and now I see that the VA can be locked out. Wasn't aware of that before. Not sure how that would work on a street machine...
By MoonShadow - 14 Years Ago
The reason I bought the MSD for my Vicky was the lack of vacuum advance in the Mallory electronic I had on it. Lost some low end and fuel mileage without it. I plan to put the Mallory on the roadster as its much lighter, geared lower and I plan to drive it like I stole it anyway. Chuck
By juangonzales30 - 14 Years Ago
I guess I will have to buy a John intake manifold for my 55 ford f-100 312 engine then.
By yalincoln - 13 Years Ago
the fenton intake has DM425 on the back, same as the late edmunds.
By Ted - 13 Years Ago
yalincoln (2/11/2012) the fenton intake has DM425 on the back, same as the late edmunds.Wayne. Thanks for that additional bit of information. While there were no Fenton intakes here to test during that particular dyno session, it has been assumed that the Fenton intakes used many of the same molds as the older Edmunds intakes. This was simply based on the similarity in castings between the two companies. What you found helps to reaffirm that.
i just looked at a fenton, DM424, same as edmunds, small ports. they also used the DM427, same as edmunds, they just changed the name on the castings, small port also.
By 63 f100 longbed - 13 Years Ago
i hope i get this right...thank you for all the information.Now that i'm sort of stuck with an offy,what can i do to improve it? thanks
By PF Arcand - 13 Years Ago
According to an article in YBM way back, as I recall, the Offy down runners are a very poor design, & it really shows up in testing. The problems are not likely to be readily addressed. Best re sell it cheap or shine it up & put it up on your garage wall...
By carl - 13 Years Ago
If you aren"t going to go raceing and just going to use the center carb what is the problem with the offenhouser manifold?
By Riz - 13 Years Ago
I have the offy- I did get it for a cheap price. It is definitely better than the stock 2bbl on it. From seat of the pants I am running orig 94s and G heads--figure i picked up about 40-50 hp which is nothing to sneeze at--It works while I wait to find out if Vic is ever going to repro the edelbrock or find one for the right price. Figure if I can make the swap easily if I do. Until then the only beef I have is with gas boiling in the carbs. Some phenolic spacers cured that for the time being. Worst case is I will block the heat risers if it is not just due to warm winter and winter blend gas.
The offy gets a bad rap cause it is obviously not the best performance, but I wanted a 3x2 and it was there. IMho run it since you got it and if you find a better for a good price snatch one for me.
By aussiebill - 13 Years Ago
Riz (2/23/2012) I have the offy- I did get it for a cheap price. It is definitely better than the stock 2bbl on it. From seat of the pants I am running orig 94s and G heads--figure i picked up about 40-50 hp which is nothing to sneeze at--It works while I wait to find out if Vic is ever going to repro the edelbrock or find one for the right price. Figure if I can make the swap easily if I do. Until then the only beef I have is with gas boiling in the carbs. Some phenolic spacers cured that for the time being. Worst case is I will block the heat risers if it is not just due to warm winter and winter blend gas. The offy gets a bad rap cause it is obviously not the best performance, but I wanted a 3x2 and it was there. IMho run it since you got it and if you find a better for a good price snatch one for me.As carl said run it, just because it doesnt flow the best compared to the best doesnt mean its no good! And if you are happy and can feel an improvement, enjoy it! Get tired of comparisons and myths that dont compare to reality.
Here’s a graph displaying the torque curves for three of the 3X2 intakes that were tested on the 322” dyno mule.
Where the Edmunds intake has superior lowend performance for everyday driving and the Edelbrock has a very good high end capability with only a slight sacrifice in lowend power, the Offenhauser intake falls shorts on both ends of the scale. Like Bill says, the Offy intake is still an improvement over a stock two barrel.
The 292 was factory with about 180 hp, I would say conservatively I am sitting in the neighborhood of about 230 or so with the offy and g heads, and about 12* of timing still have stock cam, pistons etc. I am not planning on wringing out all of the performance as I do not want to push the bottom end and stress a lot of 50 year old parts until I am ready to rebuild fully. It has a lot more grunt and let's face it we do 3x2s cause they look really cool, not cause they are practical. Nothing makes sense about running 3 carbs that were obsolete 50 years ago. But that is why we love hot rods. Ted has shown numerous times that you can get better performance out of a blue thunder or mummet with a 4bbl and let's face it 1 carb is way easier than 3.
The 3x2 with progressive is really nice that if I keep my foot out of it and do not bring in the outers I get pretty good gas mileage ( about 16-18 mpg) if I stick my foot in it it will jump off the line and even break loose in 2nd gear. I slung a TH 350 behind it cause my wife wanted to drive it and I got it really cheap. It was a small sacrifice to make since she actually pretended she cared when I found some cast off g heads at a swap meet for $150 for the pair. Guy actually thought they were for a dodge.
Maybe I am trying to convince myself, but let's face it no matter what you get there is always some better bit of go faster gear.
I could probably pick up a little more hp running better headers, but I am running cast wrapped ram horns cause I think they look cool as hell. It is always about how much you want to spend.
By Ivan M. Thoen - 13 Years Ago
What street mileage would you say is the equivalent of 400 pulls?
Ivan M. Thoen (9/23/2012) What street mileage would you say is the equivalent of 400 pulls?While I’ve never tried to equate dyno pulls to a highway mileage value, I have for my own record keeping purposes considered each dyno pull the equivalent of a ¼ mile dragstrip pass. In answer to Ivan’s question, then the dyno mule would have well over 100 miles of full throttle operation. Relating that to a street mile value would be difficult and would not be the same for all engines depending upon compression ratios and other factors within the engine. But for the dyno mule in a ’57 Ford being used by a teenager, let’s call the 400 plus dyno pulls roughly 4500 miles and total life expectancy of the engine in the neighborhood of 12-14K miles. While the engine is holding up fine, I’m reasonably sure that a large number of trannies have been in and out of that teenager driven car by this point. I’m obviously digressing here. In the case of the 312 dyno mule, the engine bottomend was disassembled and examined closely at pull number 365 when a cylinder wall needed servicing due to a crack in it. The engine bearings still looked extremely good at that point. Good enough in fact that they were reused and the engine is still running strong today at well over 400 dyno pulls. One thing I have found regarding engine life is the general tuneup. If the engine is always kept in good tune, then engine life is greatly extended. Any issues with fuel mixtures or ignition timing speeds up any wear issues that may be cropping up. Fuel wash ends up damaging the cylinder walls while ignition timing variances are destructive to both the valves and the engine bearings. Fuel injection and electronic ignition are both big players in keeping an engine in top tune and keeping wear factors to a minimum. The dyno mule is currently being tested with a Teapot intake manfold and that’s being used to sort out some Lincoln Teapot carbs. With another cylinder head change in the works, the engine will be used for an extensive dual quad intake test this upcoming winter.
By NoShortcuts - 13 Years Ago
Looking forward to your dual quad testing information, Ted.
THANKS for all that you do. APPRECIATED!
Regards,
