WANTED DEAD OR ALIVE
http://forums.y-blocksforever.com/Topic40027.aspx
By layourman - 15 Years Ago
This is the carb off of a 57 bird with 312 c.i. automatic. From the factory.
By Fordy Guy - 15 Years Ago
I've got one but don't want to get rid of it yet, but e-bay has one current bid 280 bucks needs rebuilt with small parts missing. forgot to get the bid number. Enter "Holley carb list 1273" and it will come up for you. You can get the small parts off of any 4150-4160 readily available.  Good luck.
e-bay has 2 listings/ 250556722317 and 370325811181
By junkyardjeff - 15 Years Ago
Does it look like a motorcraft carb from the 60s,I have one that I think is from a friends dads 57 fairlane that had a 312 and has ECZ cast in the side.  Was thinking about putting it on the 57 intake on the 292 I am getting for my 55 but might be able to be talked out of it if its the carb you need.
By yblock32deuce - 15 Years Ago
i believe i have a complete one in my carb drawer. will check and let you know
Yes it does, numbers are stamped on the air horn outside, above the choke plate the numbers I am looking for are ecz 1273-1
and also the letters AD Got one? How much? Thanks  Richard
just checked ebay, I dont see any carb at $280.00, are we looking at the same ebay?
FordyGuy- I did find it, thanks! my bird is not a police car!
I will get my carb down and check the numbers and get some pics.
Got the carb down and could not find any numbers stamped on the airhorn so this one must have had a tag,all I can find is ECZ cast in the drivers side of the carb,send me you email address and I will get some pics out to you.
By Larry D - 15 Years Ago
layourman
try this. http://cgi.ebay.com/ebaymotors/Holley-4-barrel-Carburetor-L-1273-1-1957-Ford-T-Bird_W0QQcmdZViewItemQQhashZitem4a902c080dQQitemZ320246384653QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
It's a bit pricey, but it looks complete.
The carb I have must have been off a 57 292 with a 4 bbl if the 312s have a holley.
By Ted - 15 Years Ago
Three different 4V carbs came on the 312’s in ’57 but the Holley (List #1273, ECZ-AD) is the only one I saw on the single four equipped 1957 T-Birds.  The 1957 Ford cars in my part of the country came with the Carter (ECZ-AA, ~400cfm) if automatic equipped and the Ford carburetor (~440cfm) if a standard transmission was used.  The 1957 Ford parts catalogue shows just the opposite of this regarding the transmission application though.  Passenger car 292 engines in ’57 did not come factory equipped with a four barrel carb.
Can anybody tell me where the date code would be on the carb ecz AD list 1273-1 57 thunderbird and how do you decipher them?
