Argentinian 292 Y block
http://forums.y-blocksforever.com/Topic39082.aspx
By ltman - 15 Years Ago
Hears a link to alot more pictures http://www.fordv8argentina.com.ar/292competicion.htm
Hears a link you can actully read LOL http://yblock.blogspot.com/2009/04/weslake-ford-y-block-engine.html
By LordMrFord - 15 Years Ago
Translated with Google tool...
This information was received from Sebastian Elias.
Technical characteristics of the engine coupe 1937 Ford Y-block V8 292 (F-100) of Charles A. Menditeguy. Menditeguy.
Engine produced by Ford Motor Argentina, Gral Pacheco.
Title of Y-V8 engine
Engine Type V8 to 90 degrees 4 times
Original cylinder diameter 95.25 mm.
Career path or 83.82 mm pistons.
Original career 0.875:1 diameter ratio
Original cubic volume 4778 cc. (292 pulgadas) (292 inches)
Diameter required to enter formula 87.12 Mm.
Resulting cylinder 3999 cc.
Decreased original cubic volume 779 cc.
Diameter ratio of race / 8.13 Mm original race.
Percentage decline of 16.3% volume
Ratio of diameter / stroke resulting 0.965:1
Block Material: low alloy cast iron
Firing order 1-5-4-8-6-3-7-2
Piston linear speed of 6,000 rpm. 16.6 meters per second.
Total area of 480 cm2 pistons
Location of camshaft, lateral center of the V
Roller chain drive heavy duty
Position overhead valve online
Tilting the axis of cylinder 9 degrees
Valve Type 1957 model Ford legitimate
Intake valve diameter from 48.76 to 49.02 mm.
Material intake valve nickel chrome steel
Type Ford legitimate outlets, hollow c / sodium
Diameter of 38.35 mm exhaust valves.
Weight of the exhaust valves 98 grams
Total area of the intake valves 150 cm2.
Value sup. Valves / sup.Pistons 32%
Light valve 020 "(hot inlet and exhaust)
Valve guides, integral cast iron
Height of 10.86 mm intake valves.
Camshaft timing AAA26-RCA 68-AAE 68-RCE26
Crossing the tree 52 °
Material cast iron camshaft
Valve Springs: double buffer
Closed valve pressure 277 lbs
Spring Height 44.5 mm valve closed.
Pressure with the valve open 130 lbs
Height with open valve spring 33.64 mm.
500 cc cylinder displacement
Compression ratio 9.30:1
Combustion chamber volume 60 cc.
Pistons mark Sylicum
Type aluminum alloy pistons with dome
Light assembly of the pistons 005 "
Compression rings two.
Each ring width 1,98 mm.
Width 4.74 mm oil ring scratches.
Weight of piston rings with pin and 750 grams.
Bolt Weight 110 grams.
Ford Crank legitimate and original
Type forged flange section
Bolts hairpieces
Weight rod 694 to 706 grams.
Material SAE 1038 steel crank
Length between centers from 160.53 to 160.63 mm.
Stump diameter rod 55.58 - 55.60 mm.
Treatment of polished rods and then copines
Sidelight connecting rods from 0.25 to 0.30 mm.
Light rods bearing assembly from 0.5 to 0.7 mm.
Armed tension rod bolts 30 lbs / ft.
Metal rod bearing copper-lead-indium
Crankshaft cast benches
Number of seats five
Light bearing bed from 0.5 to 0.7 mm.
Tension bolt assembly of bed 70 to 80 lb / ft
Standard flywheel
Diameter and weight of the flywheel 353 mm. 9,5 kg. 9.5 kg.
F-100 clutch with hydraulic legitimate.
Clutch Diameter 11 "(279.5 mm).
Arevalo radiator water mark of 5 rows.
Ratio 1.75:1 water pump pulley
Flow control 286 liters per minute at 4000 rpm.
Original oil pump, 50 pounds pressure.
Petrol pump 2 pumps submerged Tokheim.
Capacity gasoline pumps 6 pounds per inch
Holley Carburetor body double.
Throat diameter 11 / 4 "(31.75 mm).
Operating temperature 85 ° water in the cylinder head.
Operating temperature of 110 ° in crankcase oil
Mallory Distributor double platinum.
Ignition Timing 12 °
Platinum contact angle 34 °
Spark plugs (depending on circuit) Champion F-10 or F-82.
Autolite type electric generator 45 amp alternator.
Alternator pulley ratio 1.8:1
By davis - 15 Years Ago
Man, i want one of those! (engine that is)
Seem to remember a story from many years back of a guy who went to South America to bring back a set of those heads only to find out that the headbolt arrangement was different than our conventional blocks. Also the heads are look very similar to the ones on the Gurney/Weslake engine at the Speedway Motors museum.
Much attention has been focused in the Y-Block community on the rare Argentina-built Y-block engines. Perhaps the most rare connection to that is the famed Weslake Ford Y-block engine built by Harry Weslake's famous British racing and aircraft engine company. According to "Speedy" Bill Smith of Speedway Motors (who has one of the few known in existence on display in his museum), the engine features aluminum heads with "Industria Argentina" cast onto them. With the fuel injection and aluminum accessories it can be only speculated that this was an engine development intended for Formula One racing which, unfortunately, never made it. However, Smith doesn't even know much about this motor, which is very similar in appearance to the famed Gurney Weslake engines based on the Ford 289, and which began development around 1965
By aussiebill - 15 Years Ago
Certaintly an engine phenonom, i have been interested in these Weslake y blocks for over 20 years and have added comments on here at times trying to give some insight to the mystery./history that i,m aware of.
No one seems to know what actual race these were designed for but some type of road race would seem logical. It was long rumoured there were only 6 pair of these Weslake heads made? yes speedy Bill Smith has a nice example of one and that one pictured on this site in the sports car is another! I can add that after the race programm ended, the heads were recast in Cast iron and used on the 292 trucks there, they have offset shaft mounted rockers that are supported on each end by a mount that is bolted through each end of the head from the outside. A good friend has a set of these CI heads,cam etc,
Eventually all the leftover  race parts were in the hands of old racing  enthusiast and he eventually sold the lot off, there were parts from the race engines and the truck engines mixed together. In recent years the windsor style heads appeared as stated but had not heard the bolt pattern was wrong, i doubt that!  Back in 1996 there was a magazine feature on a home built hot rod in Argentina that had the CI headed engine described casually as a 292 truck engine! i think at that time no one was the wiser they were rare and HP potentiaL would be significant!
While certaintly a curiosity i think its a waste of time going on about remaking these alum heads as occasionally suggested , there are just too many odd components, etc ( pipe dream)
This is my NOS unused head! and you will see the typical Weslake features of evenly spaced round ports like all their heads. The intake/exhaust ports are finely cast and so smooth, no edges. The intake side had small wedge shaped mounting plates that formed the base for downdraft carbs or injection, the CI heads ran a cast type single carb intake.
