By rgrove - 15 Years Ago
I posted about these here a while ago, and didnt really receive a lot of interest, so I finally got around to putting them on ebay. Im just trying to get them to a good home for not a lot of money - Id hate to send them to the scrap heap; Im sure someone can use them. Thanks! http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160391894469 Ron
By butchbov - 15 Years Ago
Ron, I would like to have a spare rim or 2 for my 49 coupe. Is the bolt pattern 4.5"? Thanks,
By WILD WALFORD'S56 - 15 Years Ago
Do these have the nubs for the small dog dishes (inside)...I cannot tell? If so...will these also fit a f100? thank you..Bill
By Bobwanna - 15 Years Ago
From what I can see of the ebay listing they seem to be the 4.5" B.C. with the 3 hubcap nibs on the outside for passenger cars and T-Birds. I do not think these will fit the 56 Ford PU that has the 5.5" B.C. and hubcap tits on the inside if you want to use the truck caps -Bob
By Bob's 55 - 15 Years Ago
The ad sez 15" X 5" WIDE, 5 hole. Where did the 5 on 5.5 come from?These look like standard Ford 15" rims for a passenger car.
Ron, with you were not so far away. I could use some stock rims but the shipping would kill me...
As far as I know, these are standard Ford OE rims. I dont know if they will fit pickups....They are indeed 15x 5" wide. If i knew the right way to measure bolt spacing, I would post it here. Also, these did have the "dog dish" hubcaps on them when i had them on the car. (was used with the dog dish/wire baskets) Thanks!
If they fit your '56 Ford passenger car they are 4 1/2". You measure the diameter of the bolt circle.
Here's how you measure the pattern; http://www.mrt-wheels.com/boltpattern.html
Well as it sez in the article "This is the easiest way to ESTIMATE a 5-lug bolt circle." But the true measurement is diameter of the bolt circle. But hey whatever works, right?
by that diagram, it is 4.5" Thanks!
Bobwanna (1/4/2010) From what I can see of the ebay listing they seem to be the 4.5" B.C. with the 3 hubcap nibs on the outside for passenger cars and T-Birds. I do not think these will fit the 56 Ford PU that has the 5.5" B.C. and hubcap tits on the inside if you want to use the truck caps -BobThanks. I found 5 wheels and coker wide white walls for 200.00 and have the dog dishes,and are off a 56 f100. thanks...again
