water pump pulley
http://forums.y-blocksforever.com/Topic34926.aspx
By wagonwrench - 16 Years Ago
Let's try this again! Need a waterpump pulley for 272 engine with high fan set up. (Out of '56 F-350. I have a car pulley that is too deep and center hole is 3/4''. Best as I can tell the pulley needed is 6-5/16 diameter, 2-3/8 inch deep + or -. 5/8 inch shaft hole. 1-1/4 inch spacing on 4 bolt hub. What do you have? Thanks
By Bigwin56F100 - 16 Years Ago
In about 3 hours I will be sending you pics of what I have. Hold tight they are on the way soon!
Check your email, pics have been sent. I never really looked at that pulley closely but it is quite a bit different than the pump mounted fan pulleys.
Hope this will work for you and let me know,
