TBird Manual Steering
http://forums.y-blocksforever.com/Topic33928.aspx
By suede57ford - 17 Years Ago
How does an early T-bird drive with manual steering?
I am considering converting to manual steering in my '57 T-Bird when I put a VR57 supercharged engine in it.   I want to use the crank pulley grooves to turn the blower.
I noticed the T-bird engine sits back in the chassis further than in a passenger car, so there should not be as much weight on the front tires as on the full size Fords.
It currently has a Cavalier Rack on it with a 460 big block and it drives good, but it is a power unit, and will not look very original when I put a correct looking F-code motor in it.
I drive it every weekend, so it needs to be fairly comfortable.
Thanks for the opinions.
Pat Fleischman
By paul2748 - 17 Years Ago
I have a 56 Bird with manual steering and I have no problems steering (better than my 54). If your doing paralell parking its somewhat of a strain. But you are likely to find a big difference as compared to the rack
By Doug T - 17 Years Ago
Hi Pat,
My '55 bird has manual steering and I have shortened the steerning arms a little to 'speed up' the steering.  The front tires I have are on 7" wheels. The wheel effort is pretty light and easy at any rolling speed.  Stopped or reversing it takes an effort that has become more noticable as I age.  You wont find it a problem for several more years.
By DANIEL TINDER - 17 Years Ago
While I have not owned both types (no A-B 50s Ford comparison) and can't speak from experience, my impression has always been that early power steering is more vague than modern mechanisms (?). My original 55 manual steering gives a sensitive feedback that allows detection of minor problems that might not be obvious (or irritating) to those with power. Any hub/wheel/bearing misalignment/runout causes noticeable steering wheel oscillations, for example. I believe the 55 has faster steering geometry than an original 57 setup though, so my satisfaction might not translate in your case (I never feel any disadvantage in handling/control when switching to the Bird from my Acura with power steering). But, I also have heard that turning the wheels while stopped with manual steering could likely break the sector shaft if you have radial tires. Since I live in the sticks where parallel parking is infrequent, and still have adequate arm strength, I may be an exception.
By bird55 - 17 Years Ago
Pat, I am interested in this topic as my bird has always had PS. And even though I have diligently changed, resealed, and repaired all the proper items associated with it, it has always leaked. Sometimes a lot, but always some. I may finally just remove it and go manual. I also run radials and don't have much call for parallel parking.
Althought my steers great, It does seem like too little effort some times and I might welcome the resistance on the hiway. Guess I'll find out. w00t
By speedpro56 - 17 Years Ago
No problems with manual steering on my 56 bird and actually like it better than powersteering being not having to clean up behind it all the time. I drive it everyday if the weather is good, steers great, no problems parking etc.
By BIGREDTODD - 17 Years Ago
My '56 Bird has manual steering, original sized wheels and bias ply's and I really like the steering. It's actually quicker than I expected for a manual box. Just like any manual steering, the non-rolling effort is noticeable, but once rolling at all it drops significantlly. NO plans to change it, also because I like a simple and clean engine compartment. Also removing the orignal power booster for that reason.
My '60 F-100 has a Musang II set-up with a manual rack and a 500" Cadillac engine. The Cadillac is a feather weight compared to a 460" Ford, as it's just a bit heavier than a SBC. I kept the manual steering to maintain some of the old truck feel. It retains the large factory steering wheel, but effort is still less than the factory manual box I used for years. This truck has 235/75-15 tires on the front.
I think as long as your front tires aren't too wide, you'll be really happy with it.
