hilborn fuel injection
http://forums.y-blocksforever.com/Topic32894.aspx
By jepito - 16 Years Ago
I've been working on building an injection set up for my 312. it uses hilborn throttle bodies and my own bases to adapt to the heads. I was wondering if anyone else would be interested in a set.  I'm making them by hand on my mill, but if there was enough buyers out there i would consider having a company cnc a few sets to sell.  Just thought i would throw the idea out there and see what you guys think.
By Hollow Head - 16 Years Ago
Will we see any pics before bookings? Wink
Work in progess, but its getting there Smile
Lightened up and port matched. next step anodizing.
That is pretty cool! How will the coolant and thermostat be handled?
By John Mummert - 16 Years Ago
Beautiful job!  Are the throttle bodies generic Hilborn?
for the water, i will tap the ports for AN fittings, probably -10. the 2 lines will then y together and then run back to the radiator. the car is a model T with the rad in the trunk.  using inline electric water pumps operated by temp switches, so no thermostat. Using an aluminium marine front cover with fuel pump driven off the front of cam.
The throttle bodies are sbc basic 3 pieces that i cut apart.  plan on running deflector nozzles to have even spray down the runners. Other wise half would spray down port and other half would shoot into the wall.
By LordMrFord - 16 Years Ago
Looks good.
