C1AE block and trans
http://forums.y-blocksforever.com/Topic31900.aspx
By ltman - 16 Years Ago
I have a 292 C1AE out of a 61 ford fairlane it has 1 coae head on it I have anther coae head to go with it 100 OBO
I also have the 2 speed trans complet with tork converter and flywheel  out of this car with all the shifting linkage and kick down rod 50 OBO
Im in west virginia zip 25506 Ill will deliver a resoneable distace
I got 4 292 1 of them has 113 heads on it
Still got them I also have ,belhousings, fly wheels,throtle linkage,clutch linkage, brake pedals ,clutch pedals ,z bars ,3 speed trans,To much stuff to list so if you need something just ask all differant makes and modles mercurys,fords buicks caddys studebakers and more all parts from 49-64
By ltman - 15 Years Ago
Still got the motor need to make room in my garage 50.00
By rovison - 15 Years Ago
I have a 59 Ford tranny, bellhousing and flywheel from a FE 352. I am putting it in a 59 Y-blocks 292. The flywheel I have from the Fe won't work on the Y-blocks. Would you have a flywheel with the starter teeth on the flywheel that is 15" or do I have to get a torque converter with the teeth on them. Its a Ford-o-mactic tranny.
thanks, Tom
Ive got a fly wheel off out of a 2 speed trans alrey off out of a 60 fairlane Does any 1 no if this will work on a ford o matic It is 15 inches round 148 tooth And tthe centers on the bolt hole are 10 15/16
No, the alum two speed flex plate will not work with the COM, FOM, or FMX. I have the ford pn for the flexplate that you want, just not here at the computer. I will get it for you tomorrow. These flexplates are very hard to find used and almost never see a NOS one.
Thanks Glen
Tom
I do got 1 ill cheak it out to see if its still good I was just hoping the 2 speed was the same because i alrey got it off
Still got the coae moter still togther 1 head is off but i got 1 for it Eveery thing is still stock 50.00 I can Post pictures if any 1s intersted
