Exhaust manifolds + distributor
http://forums.y-blocksforever.com/Topic30151.aspx
By ltman - 17 Years Ago
Hears a list of manifold i got
ECH-9431-A  EOH-9430-A off of 56 ford sold
EDB-9431-B sold
EDB-9430-A sold
EDB-9431-B
EDB-9430-A
I got 2 distributors 1 is out of 56 ford the other i found in the trunk of a mercury part number FA-12127-AZ
Well i no this is not a y block but maybe you guys no some 1 that can use it ITS A 55 354 HEMI short block needs rebliut with atuo trans push button
57 gmc truck motor+ trans it has a 4 speed hydromadic stiring colom MOTOR  and trans probly needs rebliut
I got a question about fitment  for a guy he want to no if these will fit his car EDB 9430 A and EDB 9431 B hears his Q
I was wondering if you have seen one of these manifolds used on a car with manual trans. it looks like it might hit the linkage as my 54 customline has a column shift. three on the tree. appreciate any info you might have as I am very interested in putting duel exhaust on my car. thanks,Dave.
'54 and '55 have the same chassis, and factory duals were available in '55, so the manifolds will work.  The tight spot is the '54 Z bar, it is a straight bar.  "55-'56 Z bars have a curve to clear the exhaust pipe.  '55-'56 Z bar will fit the '54.  '54 bar could probably be reworked.
As for the 354 hemi, Jalopy Journal site has a wanted forum, and guys are often looking for early hemis.
By Ted - 17 Years Ago
ltman (8/7/2009)
Well I know this is not a y block but maybe you guys know some 1 that can use it.  ITS A 55 354 HEMI short block needs rebuilt with auto trans push button.
Where is the engine located?  Just knowing the state would be helpful for shipping or transport purposes or if it’s worth going and getting.
Thanks guys Im i WV
By times2 - 10 Years Ago
You still on here? I am looking for the EOH-9430-A right side exhaust manifold if you still have it
