By Vaya43 - 16 Years Ago
I have a 1960 Edsel with a 292 and im having trouble finding the parts i need. I have a few things from dennis carpenter that are ok but im really needing the vacuum line for the distributor, correct hose clamps(corbin wire type?) for radiator hoses,heater hoses and the fuel lines, throttle return spring, correct looking radiator cap,correct oil pan and valve covers, correct fuel pump and fuel filter the knind that threads to the front of the carb, and does anybody know where to find a correct batterry and battery cables? Any help is greatly appreciated I have been looking and havent been able to find what i need.
By carl - 16 Years Ago
There is probably a web site for the edsel club of america Carl
By Unibodyguy - 16 Years Ago
Do a web search for TeeBird Products out of Michigan?, can't remember, they should have a lot of th stuff you need.
By YukonCor55 - 16 Years Ago
TeeBird is in Exton, PA and deals mainly with 55 thru 57 Thunderbirds and 55/56 Full Size Fords. I'm sure they'll have stuff that'll fit but it probably wont be correct for a 60 Edsel. You also might want to check some of the F-100 sites like "Slick 60s" as many Ford trucks used Y-Blocks well into the 60s. Some things like oil pans and valve covers with the embossed Ford logo are probably dead on replacements.
By PF Arcand - 16 Years Ago
Another source is Concours Parts in Nevada. Or try NAPA for the fuel pump. Those wire hose clamps may be original in design, but my experience with them is they are a bitch to work with. Unless you are doing an exact restoration, I'd use something else like stainless gear clamps...
