Goofed up on the last post. heres the rest.Gross valve lift intake .528 exh. .536
Duration @ .020 tappet lift int. 264 exh 268
valve timing open int. 7btdc close 47 atdc
open exh. 49 bbdc close 9 atdc
Specs are for cam installed 110.0 intake centerline
Duration @ .050 int. 234 exh. 238
Lobe lift int. .3300 exh. .3350
Lobe separation 110.0
Looking for a good street cam. Low end power. Idles under a grand. The car is a 57 Ford 292 (1960 engine) Offenhauser Tri-Power (not my choice, came with the car), 113 heads, Reds headers 3sp manual ( probably go to a 4sp) and a 3.55 axle. Any ideas on the spacers and a new cam? Sorry about the goof-up. Not having a good day on this thing.
