By MoonShadow - 18 Years Ago
Can I fit standard 312 pistons to a 292 without a problem? Should I do a sonic check before boring?. I guess(?) that is about 60 over on the 292. Are the wrist pin locations the same? And the big question, Is it worth it? Chuck in NH
Chuck: The 312 pistons are .050 larger than the 292. It would be a rare block that couldn't stand that. Is it worth it? If you already have the pistons, it's well worth it. If you have to buy pistons, go to about .030 over 312 to 3.830. That's what I do in the Hurricane, and supercharge it to sometimes 14 psi in the manifold. No cylinder wall problems. John
John, Thanks, that about what I thought. I do have a new set of 312 pistons with rings so boring would be the only big expense. I guess I'll go with that. Next question. Can you use an ounce scale for balancing pistons or is gram that much better? Thanks again. Chuck
Chuck: The gram scale seems to be industry standard, so it must be better. Ted will probably delete this message since he is in the balancing business, but what I use is a balance, compare pistons until I find the lightest one, then use that as a standard to lighten the other 7 to. Do the same to the rods, small ends and total weights determined the same way. Then I take a sample piston, pin and lock rings, rings, rod, and bearings to my machinist and have him balance the crank. Saves me a few coins and saves him some time. Oh yeah, the pin diameters and compression heights are the same for 292 and 312 pistons. John
By Ted - 18 Years Ago
John. I'm hurt to think that you think I'd delete your message. But you're absolutely right in the balancing process for the pistons. Find the lightest piston and then modify the remaining seven so they all all the same weight. Just be careful in where the weight is removed so that the strength of the piston is not adversely affected. A gram scale is used because of the greater resolution. There's approximately 28.7 grams per ounce so the amount of precision becomes greater with a gram scale versus that of an scale that measures in ounces.
By pegleg - 18 Years Ago
Ted, Does John mean that you think he's unbalanced? He's accused me of that! And it's possible. Frank
Gee, is it unbalanced, inbalanced our out of balance?
Gee, I'm sorry Ted that I hurt you. Now I can recommend that Moonshadow send his parts to you to be balanced. Then he'll be mad because I recommended shipping them halfway across the country when he could have it done by a local shop. I can't win. Maybe Frank has it right, I'm unbalanced. Oh well. John
Moonshadow: Ssshhhh. Don't let Ted hear this one. I have a feeling you are leaning toward making the 312 pistons weigh the same as the 292 pistons and assembling the engine, accepting the "factory balance" as OK. If this is your plan, I would determine the "average" 292 piston and match the 312 pistons to that one. I kinda expect Ted to chime in here and tell us how far off factory balance really is. Hope I didn't hurt him again. John
Hello John. Yep, I heard you. The factory balance is like all the other variances within the engine as it falls within a given tolerance when performed at the factory. Some rotating assemblies would appear to be in the ball park while others are at either end of the spectrum or range. This is just one of the things within an engine that would explain why identical engines perform completely differently. Those engines that are at the ends of the balancing specifications or ranges are the ones that ultimately have early wear issues and in worst case scenarios, actually have vibration issues that can be felt in normal driving. Having an engine or rotating assembly balanced by your local machine shop falls in that blueprinting category where you're striving to get everything just 'right' and much closer than factory tolerance. If an individual were to merely match balance the stock pistons as well as the small and big end rod weights, then that in itself would be a significant improvement regardless of the where the crankshaft balance originally was. When making a change in the piston or connecting rod weights, then the crankshaft does need to be rebalanced accordingly. The crankshaft is the piece of the puzzle that has to be done by some specialized equipment so it's difficult for the average garage guy to do this piece but the rods and pistons are fair game if not going overboard with the lightening process. I trust this helps to understand more about why to balance.
Actually my plan was to balance the rotating assembly. I hadn't thought of matching the 312 pistions to 292 specs. I figured if I balance the rods and pistons then have the crank done to their current weight it would work. Is that correct? Also, do I still want to go with a zero deck height with the McCullouch? Any recommendation on ring gaps? I've been told to open up the top ring to 20-24 thousandths. If budget permits I have a set of 113 heads that need redone. I know the ECG's I'm running now give higher initial compression but do the 113's flow better? I also plan to finally port match the heads with the intake and exhaust but will do little else than clean up the runners. One day I too will have an engine that will run! Thanks for all the help and advice, Chuck in NH
Chuck: My car picked up a couple tenths in the quarter when I went from .010 to 0 deck. I am running lower comperssion heads than you are, but also more boost. The 113s have the big intake valves and ports, should flow better. Balancing the rotating assembly is a good idea, as Ted recommended. I run .020, .016, and .016 ring gaps. I have seen evidence of the ends butting on the top ring when I tried to run them at .016. Oil ring gaps are not critical as long as they have enough. Space the rail gaps 180 degrees apart and they'll do fine. Did you get your throttle kickdown linkage, carb secondaries, and fuel pump issues fixed? I want to see Moonshadow in the 15s this year, or better yet, in the 14s. John
Not really. I have a new kick down rod coming. Mine was made of two old ones welded together. I think the length could be off which would explain the shift passing gear problem. I've always manually shifted it anyway. With a little luck I may still get an AOD into it this year. I have everything except the transmission (got screwed on EBAY). I thought the G heads were the same basic valve setup as the 113's but a small chamber? Nothing done on the carb yet. Ted did put in the plastic floats for me last year. That was a big part of it. I find it difficult to understand why the 600CFM manual secondary dosen't work correctly. I have a vacume secondary 600CFM but I'm not sure how to boost reference the secondaries. I've also wondered if I'm shifting past the power range. I've been going up to 5500-5800 and it could be too much. I have given a little thought to going to Dearborn in August to the Woodward cruise. It's two weekend before Columbus. I could visit my daughter on the way out and then make a run to "Farmer Johns Racing Emporium" for a few days before the event. If you are willing that is? Chuck I've been embarrased for too long with how the car runs! It's way too slow for what it has. Could be driver !
Chuck: You typed ECG for your present heads. Are they ECZ-G? If so, the difference between them and the 113 are negligible. If they are ECG-something, they will have the smaller intake valves. Come on down after Woodward, no guarantees of making it faster, but we can try. John
Oops they are ECZ-G heads. I just heard the 113's were the thing for superchargers. G's are higher compression. Not looking for any guarentee's just want to make use of your experience and talents. Chuck
Chuck, You're going to have to put a boot around the secondary Vacuum link and then plumb a line to the air horn to make the vacuum work right. The mechanical should work without that, shouldn't need any changes. Might be something wrong. do you have enough fuel and fuel pressure yet? Frank
Fuel pressure Idles at 4lbs and goes to 10lb with boost ref. There was a lot of discussion about the manual secondaries not being the way to go with the supercharger. Not sure why though. Also the carb is a 600CFM double pumper. Could be just too plain big! As you well know I definately not a carb guy so?? I went to the Holley site and ran their calculator came up with a 390CFM or 570CFM recommendation for a non supercharged engine. Not sure how the blow through setup changes that. AnyHoo thats were I am right now. Chuck
Chuck, The 570 should work, I think the 390's too small for your motor. The 390 is more of a V-6 or very small V-8 thing anyway. Let me think about how to do it, Jerry Ponder showed us how on the Teapots, but that was easier to reference than a 4160 series. Frank
From what I read you have to plug up all external air sources and then run a reference line to the top(?) of the vacume diaphram. Seems that shouldn't be too hard. Finding and plugging the holes/vents may be the hardest. I can drill and tap the top for a hose connection and then run it from the supercharger. I'm always leary of things I havn't done before. Chuck
Chuck, Wrong side of the diaphragm. The side with the link, that's now open to atmosphere, has to be closed off and referenced to the air horn. Frank
By DANIEL TINDER - 18 Years Ago
Chuck,
Are your "G" heads the later "posted" ones? If not, the 113s might be more suitable for a blower. I understand Fords experience with the '57 supercharged engines prompted post installation to counteract head-gasket failure.
If you plan to use 93 octane pump gas, the slightly lower compression 113s should also permit more ignition advance.
Is there a set of pictures anywhere that really shows the difference between posted and non-posted heads? I'm sort of a visual guy. Chuck
Chuck,
If Cleveland foundry logo ("CF") present, then check date code under valve guides on the left side. Anything lower than 7 (1957) 5 (May) H (8th week) likely NOT posted. Or, (I assume) if you feel around in the water jacket holes on your 113s for the posts, you should find the same structures in the same places on the "Gs"?
Chuck, The "post" runs through the water jacket on the flat area of the chamber toward the exhaust side. You can feel it by sticking a finger in one of the larger water jacket holes towards the valves. The object was to stregthen the deck in the flat area. Racers used to crack the head there with too much compression. make sense? Frank
Seems to. I'll take a look tomorrow. I've heard stories of the old style heads collapsing under boost! Chuck
By Y block Billy - 18 Years Ago
Moonshadow There is someone in Maine here who does most of the balancing and crank work for all the well known machine shops building engines that race at Oxford Plains speedway, epping and others around this vicinity. He is located in Augusta Maine and I had him balance a steel crank 292, .060 over, forged Ross pistons, mumert 272 cam etc, He is a nice guy that knows his stuff and he balanced everything from the damper to pressure plate. I used a truck flywheel and he lightened it for me and I bought an 11' clutch and pressure plate for a 63 406 setup which bolts to the truck 11" pattern and fits the T10 tranny spline which I will be using. I think He only charged me somewhere under $200 bucks for all this and I watched him do half of it so I know it was done right. His name is Jim Fortin (Auto Fabb) is his shop and his number is (207) 623-4154 Just thought I would let you know, Maybe we can hook up at a local show sometime, I usually go the Oxford show shine and drags and a few others in this area.
What is the Oxford show shine and drags? Sounds interesting. I'm in Manchester, NH so Augusta may be a bit of a drive for machine work but I will check out his prices. Sounds better than I find around here. How many other Y-Blockers do you know in the area? I've often thought about working up a show like the Y-Block Nationals (Columbus,Ohio) for the East coast. Maybe with the All Ford meet at Eping? I'd sure like to see what is lurking in the New England area. Chuck
Why don't we spend some time talking it up this spring and set a place and date for a New England Y-Block cruise in. From there we could make plans! Chuck
Moonshadow, Oxford plains speedway is on Rt 26 in Oxford Maine, it is about as close to you as it is me. They have drags every friday night where you can bring anything you want. I went last summer to test my car but just spun the tires all the way down the track, its only an 1/8 mile strip and could not get under 15 seconds with the tire spin. I was also beat by a girl in a jeep wagoneer. It was the first time I ever run and wanted to see what the car did stock. 55 Vicky, 272 with B 4bll intake and later distributor. it drew quite a crowd from the oldtime Ford guys. I pitted next to a 52 Dodge pickup and it turned out the guy was A ford man and had a 428 ford in it. The girl I guess races there every week and went to the finals. I only ran the test and tune class so I really wasn't competing against anybody, but it was a lot of fun and I plan on doing it some more this summer as I modify my car. I am first installing a T10 4 speed, then the 9" rear I got from a 57 edsel, then the motor I am building and see what the differences are each time I make a mod. As for the show shine and drags it is a big event with 500 or so classics, some just show and shine around the oval track and others drag race their classics all day into the night until there is a winner. It draws many thousands of people. As for car shows there is one every night of the summer around here with some big ones scattered throughout, some to mention are the Oxford show shine and drags, Twitchells airport in Turner Maine, Lewiston Auburn airport in Auburn Maine. and Owlhead transportation Museum which has an all Ford event which brings some nice cars out of the wood work. Sorry for getting carried away but PM me and maybe I can send you some schedules.
I'll start a new topic for this. I usually stay close to home for evening cruises. But, Oxford Plains sounds interesting. We could get a Y-Block area going there and see what develops. I'll set the topic up as Oxford Plains. Chuck
Sounds good to me but as I mentioned in the new post you started, I don't know if that many people would beat on their cars, they more or less have them to let the gas go bad and have to clean out the carb every time they use it, but I will be there whenever I can. Looking at the map from you it may be 1.5 to 2 hours but an easy drive, head east on 101 to 95 and up to the Gray exit, it would be at approximate mile 60, used to be exit 11, take a left on 26 and about 15 - 20 miles up is Oxford Plains Speedway on the right, you couldn't miss it. sorry about that, I looked at my profile and nothing was in there for an address so I will put one in.
