Y Block Performance tips? Got any?
http://forums.y-blocksforever.com/Topic23127.aspx
By slepe67 - 17 Years Ago
http://www.jalopyjournal.com/forum/showthread.php?t=339622
I posted this topic in the HAMB, and it started a hailstorm of replies.  Mostly from Ford haters.  I think that won't be an issue in here...
I'm looking for info on what the fellas did back in the day to make the Y-blocks DOMINATE the NASCAR circuit. I tried googling...must not have typed the right sequence of wording in, because I couldn't find anything...
any little piece of knowledge will work...I'm building my 292 up for LSR, looking for ideas. thanks once again. JL
I did read the Y-Block write up recently in HRD(?), and they had some good info.  Jsut wondering what I can do to make my little 292 operate to its' max potential.  Nothing TOO expensive...just stuff a normal guy can do with normal tools, and a THIN walet...Wink
By 57FordPU - 17 Years Ago
JL,
I'm not a performance engine builder, but from experience I think heads make the biggest difference in any performance application.  If any of the hp Y-Block engine builders will chime in with some specifics, I think you will have a great start (but, just a start).
By Ted - 17 Years Ago
Slepe.  Looked at the responses to your post over on the HAMB and feelings would appear to be all over the map.  A couple of things I’ve found that gets under the skin of the scrub contingent is first telling them that their beloved small block was a cheap copy of the Y and then mentioning to them that the Y was such a dominant force in 1957 that the AMA banned manufacturer participation in racing.  Past issues of the Y-Block Magazine have gone into detail on the ’56 and ’57 racing seasons and how undominant the scrubs were.
But ’57 was the zenith year for the Y even in stock performance.  Good heads, great cams, improved rocker ratios, and a multitude of induction setups including dual quads and factory superchargers all contributed to some legendary performances by the ’57 models.  And Ford engineering support was there during the year as the posted heads made their debut during the ’57 model year and that was a direct result of what was happening on the racetrack.  Performance was so good in fact that the Y was drastically detuned for the ’58 models so as not to be serious competition for the new FE and MEL engines that were being introduced.
As far as tips go, Charlie says it in that the heads are at the top of the list.  Beyond that, a good blueprinting including degreeing in the camshaft, insuring the rocker arms are all the same ratio, modifying the oiling for the rockers, and picking out a camshaft that’s optimum for your own particular combination must be included.  There’s not a camshaft out there that is a fitall so give that some serious consideration before choosing.  And pay particular attention to the induction setup as there are a multitude of aftermarket intakes out there and many are for just the wow factor and not the go factor.  A single four setup with either a modified factory 'B' manifold or the Blue Thunder is optimum in most cases.
By mctim64 - 17 Years Ago
Slepe,
As Ted and Charlie said, the heads and the cam are the key. I know most guys on here like the Isky grinds, I like to pick my own from Oregon Cams (yes, they are regrinds) and have had good luck with them. Heads, for N/A look for ECZ-G or 113 castings and for SC look for 471 or EDB-D castings.  When it comes to porting don't get carried away, bigger isn't always better.  As Ted always says to the new guys "use the search function, there is a lot of questions that have been covered in the past".  When in doubt though, ask specific questions and I'm sure you will get a quick answer.
Thanks, gents!  I have some great weapons in my arsenal, and plan to break them out soon.  I'm working the roll cage and suspension right now.  The engine/trans is next.  Thanks again.
