Change Font
http://forums.y-blocksforever.com/Topic22951.aspx
By ejstith - 16 Years Ago
[size=4]How do you change the font on here? It's so little an old dude like me can't hardly read it. I clicked on the font box and changed the size but it didn't change the size. [/size]
By rgrove - 16 Years Ago
Do you have the same problem on other sites?  If so, and if you are using internet explorer, you can change the font size for all sites you visit.  Go to "View" in the explorer bar and click on it.  You should see a choice for "text size" and can select it there.
Also, if you are looking to make it bigger on posts you start or reply to, there is a box at the top of the dialogue window (that you type in) that says "size"  That is where you can change font size..  Here is a sample of the size & #.... hope this helps
1234567
[font=Arial][size=5]Thanks
[/size][/font]
[font=Arial Black]Didn't work ....... don't use Explorer ...[size=5][/size][/font]
By Ted - 16 Years Ago
As rgrove mentions, if you’re having difficulty reading on all sites, then his fix is at the top of the list.  Another problem may be in the display attributes for your monitor being set up for too small a screen size.  If that’s the case then go to “My Computer”, “Change a setting”, “Display”, “Settings”, and then set the “Screen resolution” to something larger than you already have.  For my own monitor, the resolution is set to 1024 X 768.  Easy enough to change back if it doesn’t do the trick for you.
No I don't have a problem reading other sites. It's not my resolution. Its actually set bigger than it should be. This is the only place I don't seem to be able to change it. I can live with it until I figure it out .. Thanks anyway.
